Old 05-26-2014, 09:57 PM   #1
malpais
malpais's Avatar
Default 8BA Breather tube- last question today-really
Anyone have a photo of where the vent tube on a '53 8BA goes? Last time, I stuck it right on. This time - duh - not obvious. Don't know if it was a car or truck orginally, but came out of a truck. It isn't close in attached photo!
I know, it's dirty and the wrong color, so we don't have to go there!
Thanks, Gordon
Don't mind learning from my mistakes. Just wish I didn't learn EVERYTHING from my mistakes..
malpais is offline   Reply With Quote
Old 05-26-2014, 10:22 PM   #2
Russ/40
Russ/40's Avatar
Default Re: 8BA Breather tube- last question today-really
Both pieces are in your photo. The one on the right is upside down. The other end goes into the intake manifold. The piece on the left is upside down also. The left piece goes on the end of the other piece and curves across the front of the block and down along the side of the pan.
Russ/40 is offline   Reply With Quote
Old 05-27-2014, 10:36 AM   #3
19Fordy
19Fordy's Avatar
This will help. Mercury and Ford are the same set up.
Old 05-27-2014, 11:04 AM   #4
George/Maine
George/Maine's Avatar
I think all car pipes goes to back in 2 pieces.
The 53 truck the second pipe goes straight down.
George/Maine is offline   Reply With Quote
Old 05-27-2014, 11:10 AM   #5
oldskool
oldskool's Avatar
I did away with mine and installed pcv valve in its place
oldskool is offline   Reply With Quote
Old 05-27-2014, 11:15 AM   #6
sidevalve8ba
sidevalve8ba's Avatar
Yep, me too.
And I connected the other end to this port at the base of my rear carb.
sidevalve8ba is online now   Reply With Quote
Old 05-27-2014, 11:57 AM   #7
rotorwrench
rotorwrench's Avatar
Mercury and Ford are similar. The question mark tube attaches to the timing cover with a clamp & bolt on the left side and is the same part for all 8BA engines. The lower draft tube for most Ford engines has a downward bent about 10 inches up from the bottom and the Mercury lower draft tube has only the slightest bend near the bottom end of the tube so the whole thing will clear the big cross member.
Old 05-27-2014, 12:02 PM   #8
texas webb
sidevalve-thats clean.
texas webb is offline   Reply With Quote
Old 05-28-2014, 03:51 PM   #9
Flathead Dave
Flathead Dave's Avatar
Do away wi th the tube and go to a pcv. Works and looks better. About $45.
"Some people are like slinkys. They're not really good for anything but they sure bring a smile to your face when they're pushed down the stairs"....
Flathead Dave is offline   Reply With Quote
Old 05-28-2014, 03:55 PM   #10
V8 Bob
V8 Bob's Avatar
It can be (and has been) done for less than half that amount.
V8 Bob is offline   Reply With Quote
Old 05-28-2014, 03:59 PM   #11
prsvf1
Location: Northern Minnesota - The Cancun of the North!
I like the PCV Valve conversion for the road draft tube. What kind should one use for this application?
prsvf1 is offline   Reply With Quote
Old 05-28-2014, 09:13 PM   #12
malpais
malpais's Avatar
Thanks all for the replies. Where is should go is simple once you see it. I don't know what's different, but it seems it will not clear the crossmember in my 39 frame once I attach the pan bracket.
PCV valve seems like a great solution.
Appreciate you taking time to answer and even post photos.
Gordon
Old 05-29-2014, 05:54 AM   #13
FordCustom
So there is a second piece to the tube coming out of the intake? Interesting.... Mine just has the one tube, shooting straight down between the water pump and crank pulley. Is the other piece available, or do you have to get lucky and find a complete original truck/car to snag one off of?
FordCustom is offline   Reply With Quote
Old 05-29-2014, 07:19 AM   #14
V8 Bob
V8 Bob's Avatar
I have some available. PM me if interested.
