11-07-2021, 06:18 AM | #1 |
1954 Ford 239 Flexplate
Hi,
My son has a 1954 Ford with a 239 y block and it has a broken flex plate. In looking at the different suppliers of the updated flex plate none of them shows it will work on his 239. I also see in the flat rate manual the 1954 carries a different part number than the 55-56 did. Does anyone know if the updated one will indeed work on his 239? Thanks Steve |
11-07-2021, 10:01 AM | #2 | |
Re: 1954 Ford 239 Flexplate
Please do me a favor, when the plate is replaced take a quality photo and post it within this thread. I would like to know how it looks. |
11-07-2021, 10:15 AM | #3 |
Hi KULTULZ,
Thanks for the reply. I sure will post a photo if and when he pulls it out, as he may change mind and repower or sell. I'm assuming then that that service part number flexplate is limited to the 1954 239 & 223 and the 55-56 will not work? Thanks again Steve |
11-07-2021, 10:28 AM | #4 | |
Do you need a possible parts source? |
11-07-2021, 10:45 AM | #5 |
Yes Please. Thanks
11-07-2021, 10:49 AM | #6 |
- https://www.ford-trucks.com/forums/1...1-p-400-a.html |
11-07-2021, 12:57 PM | #7 |
Thank you very very much. With your information I was able to grab one on ebay, thus a Christmas present for my son.
11-09-2021, 10:14 AM | #8 | |
55, or 56 will work. Mine is good at this time, but it would be beneficial to know. (Air cooled Ford O Matic trans).
IN GOD WE TRUST - SEMPER FIDELIS John |
11-09-2021, 11:11 AM | #9 | |
But you have to confirm what trans is actually in the car (as it may have been changed) and that indeed the engine is a 1954 EBU 239CI.
***** - DISCLAIMER -
The above posted information is in my opinion only (IMO) and may contain copy and paste material(s). In addition, any above tech information is supplied in good faith. No responsibility implied or otherwise can be accepted for the way others use or interpret provided data. Your experience(s), opinion(s) and mileage may vary. DIAGNOSED CDO - (OCD In Correct Alphabetical Order) Last edited by KULTULZ; 11-09-2021 at 12:59 PM. Reason: ADD INFO |
