10-08-2017, 08:48 AM | #21 | |
Re: Ford 150 OD Transmission install in 31 Roadster
And if I wanted an OD I would mount it behind this transmission. |
10-08-2017, 08:50 AM | #22 |
10-08-2017, 09:21 AM | #23 |
The pictures posted are the F150 RTS OD 4 speed transmission from Ford showing how the tail shaft has been removed and an adapter plate installed for the torque tube.
AL in NY |
10-08-2017, 09:33 AM | #24 |
If you look closely at the second photo posted you'll see a couple of transmissions sitting on a bench that have (pretty sure) the MAC's Speed Shop bell housing installed. See link below to view this part. Many people use this bell housing instead of the "AA" bell housing when they install the F150 transmission.
http://macsspeed.com/index.php/produ...inium-castings
AL in NY |
10-08-2017, 12:01 PM | #25 |
This might interest someone, a rebuilt RTS OD transmission;
http://hermtheoverdriveguy.com/rebui...rdrive-31-1150
AL in NY |
10-08-2017, 02:34 PM | #26 |
It pulls this gear effortlessly even up reasonably steep hills. I'm not sure of my diff ratio as it's a quick-change, but pretty close to standard I think. Having discovered too late that there are in fact three ratios available, the general advice was 41% for V8s and 35% for Model As. With the diff ratio I have, I am doing 1670rpm at 62mph |
10-08-2017, 03:58 PM | #27 |
Yes but its geared higher.
10-08-2017, 05:16 PM | #28 |
It has a 15% higher gear in first and second. Third gear is still 1:1, not overdrive. Read post #21.
12-17-2017, 08:51 PM | #29 |
Hi all I'm new, first post but I've been lurking for several months.
I bought an RTS with the 38% for 125.00, for my 30 coupe. 1st and 2nd have higher gear set, if OD is too high for Western Mass hills I can switch to 4:11's I picked up a 32 BB bell housing cheap. I think its the same size as a AA? Only, the BB doesn't have the mount for the radius rods. Has anyone fabricated a mount for a BB bell, so it would work in a Model A car? |
12-18-2017, 01:28 PM | #30 |
I wish there was a resource that would simplify all the above, and at the same time state if any torque tube modifications are needed. I get snowed in when so many solutions are being discussed at the same time. Help!
12-18-2017, 03:06 PM | #31 |
Check out Macs Speed Shop website. He has a bell housing available and I think an adaptor to enable retaining the torque tube.
I have the 41% F150 box in my car with an open prop shaft. It has an improved motor and honks along happily at 60mph and will pull up most hills in overdrive, only dropping back to top gear for tight corners and steeper gradients. Love it!http://www.macsspeed.com/ |
12-18-2017, 06:12 PM | #32 |
Ditto on what Al from NY wrote. I love my 27% OD but 1st gear is almost not needed unless your on a fair grade to start out.
12-18-2017, 06:57 PM | #33 |
I have the RTS 3+1 27% OD, with 3.78 rear, closed drive line. IMHO, that's the perfect combination.
12-18-2017, 07:18 PM | #34 | |
I'm going to make the modifications to the 38% and when I'm done, I'll let everyone know how it turns out. John |
12-18-2017, 07:26 PM | #35 |
12-18-2017, 07:30 PM | #36 | |
The guy that I got mine from builds them that way using all new gears regardless of what they were originally. Sent from my iPhone using Tapatalk
12-18-2017, 08:59 PM | #37 | |
Bob |
12-18-2017, 09:44 PM | #38 | |
12-18-2017, 09:52 PM | #39 |
Retaining the torque yes, does it need to be shortened?
12-18-2017, 10:48 PM | #40 |
Russ. anytime one changes the transmission in a Model A, and that new transmissoin is longer than the original Model A transmission, such as the F150 3-1 OD transmission, the Torque Tube will have to be shortened.
I have built lots of the F150 conversion Kits and every one of them had the Torque shortened. Without going to the shop to measure I think the Torque Tube and the Drive Shaft were shortened 2 3/16" .....and that is with using the AA Bell Housing. Radias Rods are also shortened. The main reason for using the AA bell Housing is to avoid cutting into the Center Cross Member. |
