Old 10-17-2021, 11:36 AM   #1
PeteVS
PeteVS's Avatar
Default Turbo Flat Head
I saw this car at a show in Ringoes NJ yesterday and thought that some of you might be interested.
Old 10-17-2021, 01:14 PM   #2
19Fordy
19Fordy's Avatar
Default Re: Turbo Flat Head
Is that a V8 60?
Old 10-17-2021, 02:15 PM   #3
Ronnieroadster
Ronnieroadster's Avatar
Originally Posted by 19Fordy View Post
Is that a V8 60?
No its a 24 stud flathead
I use the F word a lot no not that word these words Flathead , Focus and Finish.
"Life Member of the Bonneville 200 MPH Club using a Ford Flathead block"
Owner , Builder, Driver of the First Ford Flathead bodied roadster to run 200 MPH Record July 13, 2018 LTA timing association 200.921 in one and a half miles burning gasoline.
First ever gas burning Ford flathead powered roadster to run 200 MPH at Bonneville Salt Flats setting the record August 7th 2021 at 205.744 MPH
Old 10-17-2021, 03:58 PM   #4
V8COOPMAN
V8COOPMAN's Avatar
Is that a V8 60?
The easiest way to ID a V8-60....they're the only one WITHOUT a stud RIGHT ABOVE a spark plug hole.
V8-60 (17-STUD)
21-STUD
24-STUD
Click Links Below __
T5 W/TORQUE TUBE
Old 10-17-2021, 05:09 PM   #5
Bored&Stroked
Bored&Stroked's Avatar
Or . . . just look at it and count the studs . . . 17 is the magic V8-60 number . . .
Old 10-17-2021, 05:31 PM   #6
mercman from oz
mercman from oz's Avatar
Flathead powered Model A Tudor Sedan.
Old 10-17-2021, 06:33 PM   #7
Bored&Stroked
I don't know . . . all that plumbing . . . worse than 'Snakes on a Plane' to me! LOL
Old 10-17-2021, 07:38 PM   #8
38 coupe
38 coupe's Avatar
Following the path of the intake it is apparent there are a lot of 90 degree angles between the carburetor and the intake manifold which looks to me to reduce the benefits of forced induction a bit. Also, I'm not a turbo guy, but I thought modern turbos didn't like wet flow (draw through from a carburetor).
Old 10-19-2021, 09:55 AM   #9
saltracer
trying to figure out the routing of the intake charge. Something like this I guess
saltracer is offline   Reply With Quote
Old 10-19-2021, 10:36 AM   #10
flatford8
flatford8's Avatar
Congrats to the person that pulled it off but, too much going on there for me.....I like Flatheads because they’re simple......Mark
I'm thinkin' about crankin'
My ragged ol' truck up
and haulin' myself into town.
Billy Joe Shaver
Old 10-19-2021, 11:07 AM   #11
AnthonyG
AnthonyG's Avatar
I’m missing where the forced turbo air gets into the carb?
From the side? Looks like a regular 4 barrel not a side draft like the Olds Jetfire setup?
Please someone who knows “Splain it Lucy’s”
Nomad
AnthonyG is offline   Reply With Quote
Old 10-19-2021, 12:47 PM   #12
novaskilling
I was wondering the same thing? Looks like it blows into the intake under the carb?
novaskilling is offline   Reply With Quote
Old 10-19-2021, 03:52 PM   #13
tubman
tubman's Avatar
Hmmm, After Anthony's post, I went back and looked at it in detail again. I can't see how it works either.
Old 10-19-2021, 04:11 PM   #14
Cliff Ramsdell
Cliff Ramsdell's Avatar
So that setup looks like its off of an old pontiac 301 turbo motor from 1980/1981.
Pretty simple, uses a quadrajet on the adapter, gets pulled into the turbo and then the outlet goes into the intake manifold. Its a "wet" setup made to move fuel through the turbo.
The stock turbo 301 intake just had a round hole where the turbo bolted up to it.
Cliff Ramsdell
Cliff Ramsdell is offline   Reply With Quote
Old 10-19-2021, 08:50 PM   #15
Holeshot
Cliff is Right!
"Sometimes he would accuse chestnuts of being lazy, the sort of general malaise that only the genius possess and the insane lament."
Holeshot is offline   Reply With Quote
Old 10-19-2021, 09:04 PM   #16
38 coupe
38 coupe's Avatar
No matter the performance change I would not be willing to put a quadrajet on a flathead V8.
Old 10-20-2021, 02:19 AM   #17
tubman
tubman's Avatar
You're right. I tried using a Quadrajet from of a 3.9 Liter Buick a couple of years ago because I happened to have a spare Sharp 4 BBL manifold and a variety of adapters. I couldn't get it to run decently no matter what I did, so I gave up after a while. I think it had something to do with the stack of adapters I had to use just to get the carb mounted. I probably could have made it work by butchering the Sharp manifold, which I wouldn't do.
Old 10-20-2021, 06:41 AM   #18
mfirth
Well, if it runs good, ya gotta give the guy credit. However, for me all the plumbing spoils the charm of a Flatty and that nice high boy. Rather have a super charger....??
mfirth is offline   Reply With Quote
Old 10-20-2021, 01:46 PM   #19
Automotive Stud
Automotive Stud's Avatar
I don't see much point in putting a big turbo on a low revving engine, but I guess it could have been a "lets see if I can do it" deal.
Automotive Stud is offline   Reply With Quote
Old 10-20-2021, 07:25 PM   #20
Bored&Stroked
I don't know if it is a 'Big Turbo', but they can be highly effective if the system is correctly designed, things are sized to meet the specifics of the engine and usage, etc..
Keep in mind, that diesels are not high-revving engines, yet every diesel truck I've owned and almost every piece of construction equipment has a diesel engine, with a turbo on it.
