Old 07-14-2021, 01:50 PM   #1
leon bee
Default Up to Date Info on a 6 Volt Fuel Pump?
I got one car just needs a little boost sometimes to start. And I'd like to have a 6v pump around the shop anyway. Seems like not long ago I studied this out, everybody was liking a certain Facet pump, or maybe a Purolater. Well I guess it must have been a few years ago. I spent 2 or 3 hours googling: seems facet quit making the pump, Purolator sold out to somebody offshore, etc.,etc.,etc. Search out 6v pumps, man, you don't know what you're looking at.
So the question: anyone bought one recently they're pleased with? The kind the mechanical pump will suck through? Thanks a lot!
leon bee is offline   Reply With Quote
Old 07-14-2021, 02:31 PM   #2
Kens 36
Kens 36's Avatar
Default Re: Up to Date Info on a 6 Volt Fuel Pump?
Check the Airtex E8902. Low pressure, allows pass through. Available from various suppliers - under $40.
https://www.nirgv8.org
Kens 36 is offline   Reply With Quote
Old 07-14-2021, 02:41 PM   #3
19Fordy
19Fordy's Avatar
Whatever you get, make sure it does not have a
rubber diaphragm that will turn to "mush" when subjected to gasolene.
The old WALBRO pumps come to mind.
19Fordy is online now   Reply With Quote
Old 07-14-2021, 02:46 PM   #4
Bruce_MO
My Airtex has worked great as a startup helper for years. I only use it for priming after sitting for a long time.
Bruce_MO is offline   Reply With Quote
Old 07-14-2021, 08:15 PM   #5
Anteek29
Anteek29's Avatar
Same here as what Bruce wrote.
Alan
1929 Special Coupe
1941 Pick-Up
1955 Victoria
Anteek29 is offline   Reply With Quote
Old 07-14-2021, 08:46 PM   #6
51woodie
51woodie's Avatar
Airtex on my '46 works for me.
51woodie is offline   Reply With Quote
Old 07-14-2021, 09:06 PM   #7
leon bee
Looks like Airtex E8902 is it. Thanks everybody.
Old 07-14-2021, 10:59 PM   #8
tomcarman
tomcarman's Avatar
Is that a fuel pressure regulator attached? If so what is the PSI and does it come with the pump.
Thanks, Tom
tomcarman is offline   Reply With Quote
Old 07-14-2021, 11:59 PM   #9
leon bee
I guess that's what I meant by up-to-date. These E8902s don't seem to be around much any more. Sears shows one for $140.
Old 07-15-2021, 12:16 AM   #10
tomcarman
tomcarman's Avatar
Poking around on Summit Racing site I found some info. I'll have to look again. My eyes are drooping as it's late.
Old 07-15-2021, 06:22 AM   #11
Pat/Ohio
Pat/Ohio's Avatar
Thanks, Tom
Tom, That is a fuel filter attached to the rear of the pump. I have used these E8902 Airtex pumps for years with no problems.
Stay Safe,
Pat
Pat/Ohio is offline   Reply With Quote
Old 07-15-2021, 02:27 PM   #12
Fritz
Fritz's Avatar
The Airtex should be the one in the Macs catalogue and website. It’s where I bought mine.
Cars and metal rust away and are destroyed, but the Word of God will stand forever (Isaiah 40:8, Matthew 24:35).
Fritz is offline   Reply With Quote
Old 07-15-2021, 02:41 PM   #13
J Franklin
J Franklin's Avatar
The Covid has made many things hard to get or out of production.
J Franklin is online now   Reply With Quote
Old 07-15-2021, 07:50 PM   #14
ursus
I have heard that one could run a 12-volt fuel pump on 6 volts and that it would operate at lower pressure. Is this possible?
Old 07-15-2021, 09:26 PM   #15
51woodie
51woodie's Avatar
I did a fuel pressure test with the 6 volt Airtex on my ‘46, and it puts out 3 psi. That was done using a high quality 0-5 psi gauge, so no pressure regulator needed.
Old 07-15-2021, 10:06 PM   #16
fordor41
fordor41's Avatar
Purolator/ Facet pumps can be a pain in the ***! The are/were filled with a gas to help stop contact arcing but the gas would leak out and the pump would quit. tap it with something and they would start up again for whoever knows how long
fordor41 is offline   Reply With Quote
Old 07-15-2021, 10:52 PM   #17
leon bee
I've wondered, too, cause there was always this Carter looking pump in the Mac's catalog said it could be run either 6 or 12. I have a couple of similar looking 12v pumps here, (different numbers on them) tried them on my 6 volt battery......nothing.
Old 07-15-2021, 10:55 PM   #18
tubman
tubman's Avatar
We're car guys; someone should try this. (Back in the day, I spent more on beer in one night that one of these pumps would cost.)
Don't ask me; I am one of those who believe that the Ford engineers got it right the first time, and that electric fuel pumps are "band-aids".
Old 07-15-2021, 11:56 PM   #19
leon bee
Denny, a band-aid, in this case, is what I need. That is, someone else owns the car.
(I just slop gas down the throat of my own cars).
Old 07-16-2021, 07:59 AM   #20
BUBBAS IGNITION
BUBBAS IGNITION's Avatar
Google the number there are tons of them available , i lke the ones that come with a new fuel filter . Remember they should push NOT pull ....l
If it Makes Spark, we do it !!!!
www.bubbasignition.com
[email protected]
BUBBAS IGNITION is offline   Reply With Quote
