10-17-2016, 12:45 PM | #1 |
General degreasing - any recommendations?
While I've got the head off and the car in the middle of some repairs, I want to also give a really good degreasing to clean it up and also help to identify if/where there are any oil leaks.
Questions are as follows: (1) What is a good general purpose degreaser? Most of the gunk seems to be built up in that trough behind the bottom of the radiator, but there's also a fair amount on the bottom of the engine and generally all around the undercarriage. The car has been driven almost daily for 15 years, and I don't think we thoroughly degreased/cleaned the undercarriage even then, so I imagine it's a combo of oil and collected road grime. (2) What areas should absolutely NOT be degreased? (This is more aimed at the undercarriage.) I understand grease isn't all bad, or it wouldn't be there in the first place. What areas should I absolutely avoid removing all of the grease? (3) After it's good and clean, are there certain areas in particular prone to leaks that I should pay special attention to? I'll likely have a lot of questions going forward. The car was mine and my dad's and he usually had all of these answers. He recently passed and I'm now the sole caretaker of our beloved Cabriolet (68 C). My son turns 16 when the car turns 100, so it's my goal to get it to there. I was always the one that excelled at the mechanical and electrical stuff, so I'll be relying on the Barn to fill in the gaps. Thanks in advance.
I was born in 1982 and in 1989 my father found the perfect '31 Cabriolet. In 1997 he finally bought it and it became our favorite thing to do together. While my friends were buying Playstations and XBoxs, I was saving up for a muffler. 9 years later, while their game systems were gathering dust, I was picking my wife up for our first date in that car. I drive it to this day and I hope to keep it up so my son can enjoy it just the same. That's the joy of a Model A! |
10-17-2016, 12:52 PM | #2 |
Re: General degreasing - any recommendations?
leakage from ~35 zerk fittings + engine + transmission + steering column over the last 80-90 years adds up to the undercarriage.
I doubt the factory intentionally smeared grease on any exterior surface I found the spray degreasers work "so-so" Brake clean + plastic spatula works reasonably well on the caked on stuff.
1929 Tudor |
10-17-2016, 01:00 PM | #3 |
Amen to that! It's been many many years since I hit all those grease fittings. You just added a big one to my to do list!!!
10-17-2016, 01:02 PM | #4 |
http://www.cleaningsuppliesoutlet.co...strial-gl.html
used that stuff at work, would remove years of caked on grease, machine coolant, general grime. simple green is also very good. Alot of people use oven cleaner - use outside as fumes are ridiculous haha.
10-17-2016, 01:03 PM | #5 |
Brake Clean works very well but be Careful as the fumes are deadly.
"If I asked people what they wanted they would have said faster horses." -Henry Ford "Primitive technology is not a design flaw" 1928 Ford Model A Roadster Pickup 1930 Gordon Smith Air Compressor 1941 Willy's Pickup 1960 Thunderbird-For Sale 1964 Buick Riviera 2x4 425 1965 Pontiac GTO, 455 Super Duty 2004 Dodge Ram SRT-10, V-10 Viper 1977 Charger Jet Boat,460 Ford,Jacuzzi Jet Front Engine Nostalgia Dragster,Supercharged 296 "Fullrace Flathead" Ford Engine Build up on DVD ask |
10-17-2016, 01:09 PM | #6 |
10-17-2016, 08:00 PM | #7 | |
My car had a rock-hard crust of dust and grease covering all the mechanical parts, and nothing worked at all to get it off. Then I tried Easy-Off, and it did a great job! But it will absolutely remove all the paint!
Doug Quote:
My '31 S/W sedan project:http://31ford.dougbraun.com My restoration diary: http://dougbraun.com/blog |
10-18-2016, 01:57 PM | #8 | |
10-17-2016, 01:21 PM | #9 |
Pour charcoal starter in a spray bottle. Spray on the offending area and let it sit for a few minutes then agitate with a parts brush. Do a final rinse with garden hose. Won't harm paint, no noxious fumes and very cost effective.
I Love Anything That Turns Money Into Noise |
10-20-2016, 06:49 PM | #10 |
I thought you were going to say: "throw a match at it"
10-20-2016, 07:29 PM | #11 |
https://www.amazon.com/Permatex-0140.../dp/B000HBNV76 Hand cleaner,DL is not as strong as before but let it sit over night hose off, works real well. Pete
10-17-2016, 01:35 PM | #12 |
Use a power washer where practical ! Wayne
10-17-2016, 01:45 PM | #13 |
Oven cleaner works well, but it also removes paint. I'd use a parts cleaning brush for the caked on junk, or a paint brush for the light stuff and use diesel fuel to soften and remove the dried junk.
10-17-2016, 04:03 PM | #14 |
I recently used a degreaser called "Purple Power". I bought it at Auto Zone. It comes in a spray bottle and it worked great.
10-18-2016, 02:11 PM | #15 |
I like the purple power also. The best part is that it does not leave a residue, so you can paint item immediately after the part dries up.
Henry' s 31 |
10-17-2016, 04:12 PM | #16 |
A friend sprays crummy areas for 2 or 3 weeks, with WD-40, before cleaning. I DON'T know if it really helps or not.??? I'm sure it wouldn't harm anything.
Bill W.
10-17-2016, 04:31 PM | #17 |
For lite to moderate cleaning I use Purple Power. For really caked on grease and dirt I use diesel fuel under air pressure. Get a siphon tube and nozzle at your auto store. A good compressor and a can of diesel will tear right thru the crud. Then follow up with the PP.
10-17-2016, 06:04 PM | #18 |
Simple Green (the green stuff) not the yellow Simple Green. Usually you can find a gallon jug that comes packaged with a quart bottle that is pre-mixed. I like the quart bottle because you can set it so the spray comes out as a foam that sticks well to things. I use it full strength for de-greasing.
Dave / Lincoln Nebraska |
10-17-2016, 06:17 PM | #19 |
I have used "Greased Lightening ", from BJ's club. Works great, and if you can Rince with hot water, the surfaces are ready to paint.
Good Luck;
Brian French; 1930 Briggs Town Sedan |
10-17-2016, 08:09 PM | #20 |
Purchase a steam cleaner at Walmart.com or Harbor freight for about $100 bucks before discount. McCulloch steam cleaner. Cover distributor, generator, alternator or other electrical components first.
Dawn dishwashing liquid. Cleans grease off ducks, cars and hands very well. Purple Power. Easy Off. Simple Green. MINERAL SPIRITS as shown in this video below: https://youtu.be/jttcGiGPzR4 Last edited by coupe1942; 10-18-2016 at 06:12 AM. |
