Old 05-10-2010, 06:38 PM   #1
frank long island
frank long island's Avatar
Default timing for 292
can someone tell me the timing for a 55 292 4bbl stick thanks keep up the good work
frank long island is offline   Reply With Quote
Old 05-10-2010, 08:24 PM   #2
BOSSY
BOSSY's Avatar
Default Re: timing for 292
I believe it is 6% on mark. If you are setting the timing chain, that's another story.
BOSSY
BOSSY is offline   Reply With Quote
Old 05-10-2010, 08:40 PM   #3
paul2748
paul2748's Avatar
The 6 degrees is correct, but try a little more. The Yblocks seem to run a little better with a little more initial timing.
Old 05-10-2010, 09:40 PM   #4
Bill Steiner
I agree , 6 to 8 dg. Depends on gas. Bill
Bill Steiner is offline   Reply With Quote
Old 05-10-2010, 10:58 PM   #5
Retro Jim
Retro Jim's Avatar
Yep , 6 will get you right on .
Jim
Retro Jim is offline   Reply With Quote
Old 05-10-2010, 11:13 PM   #6
frank long island
thanks
Old 05-12-2010, 09:29 AM   #7
mctim64
mctim64's Avatar
6* may be what the book shows but 12* works better in most cases. If you want to time the cam fallow this link.
http://yblockguy.com/yblock_005.htm
mctim64 is offline   Reply With Quote
Old 05-13-2010, 02:26 PM   #8
LOWRIDER
LOWRIDER's Avatar
Tims the man on y-blocks. Follow what he advises.
LOWRIDER is offline   Reply With Quote
