05-10-2010, 06:38 PM | #1 |
timing for 292
can someone tell me the timing for a 55 292 4bbl stick thanks keep up the good work
05-10-2010, 08:24 PM | #2 |
Re: timing for 292
I believe it is 6% on mark. If you are setting the timing chain, that's another story.
BOSSY |
05-10-2010, 08:40 PM | #3 |
Re: timing for 292
The 6 degrees is correct, but try a little more. The Yblocks seem to run a little better with a little more initial timing.
05-10-2010, 09:40 PM | #4 |
Re: timing for 292
I agree , 6 to 8 dg. Depends on gas. Bill
05-10-2010, 10:58 PM | #5 |
Re: timing for 292
Yep , 6 will get you right on .
Jim |
05-10-2010, 11:13 PM | #6 |
Re: timing for 292
05-12-2010, 09:29 AM | #7 |
Re: timing for 292
6* may be what the book shows but 12* works better in most cases. If you want to time the cam fallow this link.
http://yblockguy.com/yblock_005.htm |
05-13-2010, 02:26 PM | #8 |
Re: timing for 292
Tims the man on y-blocks. Follow what he advises.
