Old 05-18-2020, 12:47 AM   #1
Russ/40
Russ/40's Avatar
Default Engine Builders Question
I have run into a problem on an engine I am currently building. The block is a '41 with the sleeves pulled and bored to std. 3 3/16." The problem is when it was bored, no chamfer was made to remove the portion of the top most bore area that the original sleeve sat upon. With my spring compressor when I try to run the piston down, the lower steel ring portion of the oil ring snaps into this small depression around the bore preventing me from getting the piston fully down the bore.
I'm using the spring steel type of compressor. Any ideas to bypass this obstruction and get the piston and rod down the bore without damaging the rings?
My pistons are 4 ring. The bottom oil ring is no problem, but the upper oil ring with the expander setup is the problem.
Russ/40 is offline   Reply With Quote
Old 05-18-2020, 04:25 AM   #2
flatheadmurre
flatheadmurre's Avatar
Default Re: Engine Builders Question
The compressors that is a steelband sometimes can go down into the notch...
Old 05-18-2020, 09:18 AM   #3
Russ/40
Russ/40's Avatar
I just can't get mine to set that well.
Old 05-18-2020, 07:28 PM   #4
Ronnieroadster
Ronnieroadster's Avatar
On the few blocks i did like yours remove sleeves and bore to 3-3/16 a slight chamfer was added at the top of the bore this eliminated that step. The chamfer was accomplished by using a cone shaped sanding drum in a hand drill. The machine shop that bored the block should have a similar sanding drum most shops do this to the cylinders after the bore to help guide the rings in.
Ronnieroadster
I use the F word a lot no not that word these words Flathead , Focus and Finish.
"Life Member of the Bonneville 200 MPH Club using a Ford Flathead block"
Owner , Builder, Driver of the First Ford Flathead bodied roadster to run 200 MPH Record July 13, 2018 LTA timing association 200.921 in one and a half miles burning gasoline.
First ever gas burning Ford flathead powered roadster to run 200 MPH at Bonneville Salt Flats setting the record August 7th 2021 at 205.744 MPH
Ronnieroadster is offline   Reply With Quote
Old 05-18-2020, 07:34 PM   #5
JSeery
JSeery's Avatar
Not sure how much trouble you want to go to, but you could have a tapered sleeve machined to install the pistons/rings and machine a lip into the bottom of it to fit the block. Might be able to use one of these type of installer and just add the lip to the bottom of it somehow.
Or maybe something like this: https://www.prlog.org/12641500-ipd-a...5-engines.html
Old 05-18-2020, 07:35 PM   #6
Russ/40
Russ/40's Avatar
Ronnieroadster
I agree with what you say, but, I have a valve train and crank in place and don't intend to start grinding on bores now. Looking for a better ring compressor. I have ordered one of the taper ring compressors I will modify if necessary. Would be nice if someone that has tried this would come forward and fill me in on their experience.
Old 05-18-2020, 07:40 PM   #7
JSeery
JSeery's Avatar
Think you are on the right track.
Old 05-19-2020, 10:21 PM   #8
Fordestes
Will there be any sharp edges to worry about causing a hot spot if left not chamfered ?
Fordestes is offline   Reply With Quote
Old 05-20-2020, 10:42 AM   #9
rotorwrench
rotorwrench's Avatar
I don't know what the step dimensions are but I would find something hard to fill the step but still have the same ID as the cylinder wall. It could be made from wire but it would have to be soft enough to not damage the rings and hard enough to let them pass over it. I've had to do this on hydraulic cylinders before.
A lathe would be handy to make a guide sleeve but a person would have to have one to fabricate a specific sized guide sleeve. A cylinder sleeve could be used to speed up the process.
Old 05-20-2020, 10:53 AM   #10
Russ/40
Russ/40's Avatar
Interesting thought, but I don't think there is enough meat there to matter. The step is probably .025 x .025" approximated.
Old 05-20-2020, 11:00 AM   #11
Russ/40
Russ/40's Avatar
GREAT ! Point rotor wrench !
I didn't think of that. Forgot I actually have a few 3 3/16 sleeves, and I have a lathe if I need it. Good info !
I knew a few extra brains would help.
Old 05-20-2020, 11:04 AM   #12
deuce_roadster
deuce_roadster's Avatar
Would stuffing a rag down in the cylinder and using a ridge reamer take that sharp edge away? You could vacuum out any filings created. You might be able to taper the cutter to make a chamfer. Just a thought.
Old 05-21-2020, 12:43 AM   #13
Russ/40
Russ/40's Avatar
Took the 3 3/16" sleeve and ground the bottom to a knife edge all the way around. It made the perfect ring compressor to slide the loaded piston past the offending notch that was grabbing the 3rd ring. That comment did the trick. Thanks rotorwrench!
