Old 12-12-2019, 06:29 PM   #21
J and M Machine
Location: 40 Mt.Vickery Rd. Southborough,MA 508-460-0733
Default Re: That "Opportunity Knocks" Engine
Originally Posted by SAJ View Post
Beautiful work J and M!
Is the small circle visible in your photo or does one have to look at a real block with a loupe eyepiece? Is the circle the END of the casting wire and therefore very small? I am interested to know what to look for.
SAJ in NZ
Thank you for your compliment.
You can see it in these pictures as it is the core wire. . If you look close the factory ground it off. They are of centered over the crotch of the cylinders and its prevalent on 1930-31 model engines.
The core wire is steel and over time rots away leaving a void for the water to leak.
J and M Machine is offline   Reply With Quote
Old 12-12-2019, 06:49 PM   #22
100IH
Stitch it-Irontite pins. Then run their ceramic seal.
100IH is offline   Reply With Quote
Old 12-15-2019, 02:05 PM   #23
dumb person
dumb person's Avatar
Drilling the ends & driving in soft wire or lead should be ideal for prepping it for JB weld.
You could try to solder it with normal electrical solder. Not brazing or even silver solder, i'd consider those 'too hot'.
If you want a better compound than JB weld i hear great things about some product from belzona?
https://www.belzona.com/en/products/1000/1111.aspx
<Link> This is how we roll<Link>
"I'm Convinced that no one really reads posts anymore; they just fabricate what they think the post says then ramble on about red herrings."--Bob
Outcasts rules of old cars
#1 Fun is imperative, mainstream is overrated
#2 If they think it is impossible, prove them wrong
#3 If the science says it impossible you are not being creative enough.
#4 No shame in recreating something you never had
#5 If it were not for the law & physics you would be unstoppable
dumb person is offline   Reply With Quote
