Old 07-13-2019, 10:16 AM   #1
katy
katy's Avatar
Default Flush oil/anti-freeze mix from crankcase?
I'm currently in the process of pulling the head from my A to replace a suspect head gasket.
A few days ago I came home from a 20 mile run and noticed light green "goop" dripping from the flywheel housing, upon checking the oil it was the same goop up to about 1/2" over the full mark.
Running 50/50 water/antifreeze I'm concerned about getting as much goop out of the engine as possible.
I haven't drained the oil yet and I know I'll have to drop the pan to clean the dipper troughs out.
Any suggestions?
Old 07-13-2019, 11:58 AM   #2
ursus
Default Re: Flush oil/anti-freeze mix from crankcase?
Your antifreeze may well contain silicate compounds that are included as a stop-leak additive. Silicates are abrasive and will damage the rod and crankshaft bearings in the engine. Running the engine can generate enough heat to dry out the water but the silicates will be left in the oil. My preference is to pull the pan and valve chamber cover for a complete cleanout and an opportunity to check everything over, maybe adjust bearings, etc.
ursus is offline   Reply With Quote
Old 07-13-2019, 04:17 PM   #3
J Franklin
J Franklin's Avatar
The oil will float on top of the GOOP. Let it set a few days and drain the oil without running first. Then just leave a pan under it and let it drip for a day or so till dry.
Old 07-13-2019, 10:00 PM   #4
100IH
The problem here is the dipper pan and it's 1/2 quart of anti freeze.
100IH is offline   Reply With Quote
Old 07-13-2019, 10:58 PM   #5
J Franklin
J Franklin's Avatar
Drop the pan.
Old 07-14-2019, 08:08 AM   #6
Patrick L.
Patrick L.'s Avatar
You might try dumping a couple qts of oil thru the distributor hole if you don't want to remove the pan.
That said, if the pan has not been removed in a couple decades then that may be a good thing to do.
Old 07-14-2019, 08:10 AM   #7
Benson
Benson's Avatar
blenco
Benson is offline   Reply With Quote
Old 07-14-2019, 12:21 PM   #8
Benson
Benson's Avatar
Blenco-2
Old 07-15-2019, 09:16 AM   #9
katy
katy's Avatar
Here's the goop that drained out, about 5 quarts:
The oil/antifreeze/water mix is not separating when left to sit, I'm suspecting that the detergent in the oil is holding it all together.
Old 07-15-2019, 09:21 AM   #10
katy
katy's Avatar
After getting the head off and inspecting the head gasket it looked fine, no signs of leaking. Although #3 cylinder shows signs of being the culprit. Upon examining the head I see that it has an old repair in the combustion chamber. Now to source a replacement head.
Old 07-22-2019, 09:12 AM   #11
katy
katy's Avatar
Update. Got a replacement head and installed it. Waiting for a new fan. Pulled the valve chamber cover and cleaned all the goop out of that area. Dropped the pan to clean it and the bottom end and found that some OP had welded the dipper tray in, lousy welding but I'm not about to alter it or try and take the tray out.
Also, I see that the oil drain tube has 2 small (about 3/32") drilled holes in it, about 1/2 way up. I don't think this is normal, should I weld/braze them up?
Old 07-22-2019, 01:59 PM   #12
katy
katy's Avatar
Here's the drain tube w/holes:
Old 07-22-2019, 02:21 PM   #13
jw hash
jw hash's Avatar
antifreeze will wipe out your bearings. once you get it running, put about five miles on the motor and change the oil. that looks to be a stock head. to me they are not worth repairing. I don`t understand the small holes in the drain tube.
jw hash is offline   Reply With Quote
Old 07-22-2019, 10:52 PM   #14
31a
drop the pan pull dipper tray and clean
31a is offline   Reply With Quote
Old 07-23-2019, 09:27 AM   #15
katy
katy's Avatar
In progress.
That's the plan, after I weld/braze up the holes in the drain tube and get it all back together with oil and filter.
Forgot to mention that it has a full flow oil filter.
Old 07-23-2019, 04:40 PM   #16
30 Closed Cab PU
What happens to small amounts of antifreeze going through an oil filter? Plug it or will the filter pass the antifreeze? The viscosity is greater, perhaps stops up the filter?
30 Closed Cab PU is offline   Reply With Quote
Old 07-24-2019, 03:30 PM   #17
katy
katy's Avatar
In my case the 50/50 antifreeze and oil mixture just blended together, see pic in post #9
The oil filter was full of the same mixture.
