09-17-2015, 01:51 PM | #1 |
Adapter for Model B Carbs ?
Some time ago someone posted that a Dealer had a adapter available that permits the gas line connection to face out like the Zenith and Holley Carbs.
Who is the Dealer that has these Adapters ? Thanks, Ron The reason I asked the Question, I have a B Top that has only threads and no seat; I was told that Zenith actually produced this Top as the 32 B had no gas filter between the gas tank and the carb and it was designed to use a 31 Side Bowl as the filter; I actually mounted a 31 Side Bowl on this top and the threads were correct and the inlet of the Side Bowl faced out. I do not plan on using this B Carb, just want to finish it as it will be For Sale and I do not want to run up the price by adding a 31 Side Bowl. Has anyone else run into a B top like this ? Last edited by Ron in Quincy; 09-17-2015 at 09:13 PM. Reason: Additional information |
09-17-2015, 01:59 PM | #2 |
Re: Adapter for Model B Carbs ?
Renner's Corner (Dave Renner) RC-9510-XC $14.00 (Just the gas fittings)
10320 E. Austin Road Manchester, Michigan 734-428-8424 Snyder's A-9510-K $31.00 (Bolts to align the choke control, gasket and the gas line fittings) |
09-17-2015, 02:33 PM | #3 |
09-17-2015, 02:42 PM | #4 |
Hi Ron, JUST GO TO ANY GOOD PARTS STORE & GET THE CORRECT FITTING.. i THINK IT'S 1/8TH PIPE, 90 DEGREE TO 5/16 COMPRESSION. I USED THIS ON MY B CARB & THE FUEL LINE WILL WORK ON BOTH A & B CARB'S GREG OUT WEST AFTER YEAR & HALF GONE. |
09-17-2015, 09:14 PM | #5 |
Ron |
Thread Tools | |
Display Modes | |
