Old 05-15-2014, 02:02 PM   #1
Dana Barlow
Question stamped # y-block? not cast in,what are they?
There is some # ? on a few of my Y-blocks stamped in on the front lip left side of vallycover, I don't know what they are?
I took the time to clean them so I could ask,one of the blocks has 2B1 E 5<but "E" is backword,another has 91V7,and my last one has 29G04=these are not cast in but stamped on the vallycover lip.
The're the only stamped # I have ever seen on "Y",I understand that Y-blocks have no vin # stamped on them,so what are these things?
Dana Barlow is offline   Reply With Quote
Old 05-15-2014, 06:20 PM   #2
streetdreams
Location: Howell, Michigan, USA, The Peoples Slightly Overspent Demodependancy of Michigan
Default Re: stamped # y-block? not cast in,what are they?
They do have factory cast part numbers also, correct ? I would suspect the stamped numbers are rebuilders or company fleet ID's.
streetdreams is offline   Reply With Quote
Old 05-15-2014, 06:43 PM   #3
y'sguy
y'sguy's Avatar
yes, I would say rebuilders marks.
y'sguy is offline   Reply With Quote
Old 05-15-2014, 09:17 PM   #4
Dana Barlow
Question Re: stamped # y-block? not cast in,what are they?
Yes,thanks, do have the cast numbers, cast in to the side of blocks,but what I'm asking about is "stamped" number#? There too clean an neatly done for rebuilders,I'm thinking the're Ford but I don't fine any info from my hunt so far. They are stamped on the left front of vallycover gasket flat of block and do show with the cover in place
I never had payed any adtenion to them before,to EZ to over look.
Old 05-16-2014, 05:19 AM   #5
darrell
those are dates when the block was built as far as I know.
darrell is offline   Reply With Quote
Old 05-16-2014, 05:26 AM   #6
rick55
rick55's Avatar
I have 56 yblock with numbers stamped there also. It had never been remanufactured either.
All Aust. Yblocks are stamped on the left front just below the head.
Rick
West Australia
1958 Ford Mainline Utility, 1955 Ford Tudor Sedan
Anyone who stops learning is old, whether at twenty or eighty. Anyone who keeps learning stays young. The greatest thing in life is to keep your mind young.
Henry Ford
rick55 is offline   Reply With Quote
Old 05-16-2014, 07:55 AM   #7
smtichy
smtichy's Avatar
Dana, I've also read somewhere that a stamp in that location is the motors assembly date. Here is a link to decode it. http://fordclassics.com/date-codes
Unfortunately the codes you mentioned don't seem to fit into this decoder. Any info you have on the origin of your blocks may give some other members a clue to help advise you. Are these in cars, trucks, or are they blocks you recovered from scrapyards?
Steve
'55 Sunliner - 292 V8, 3 speed man. w/ OD
ČKMAA - Český klub majitelů amerických automobilů
smtichy is offline   Reply With Quote
Old 05-16-2014, 09:55 AM   #8
Dana Barlow
Thumbs up Re: stamped # y-block? not cast in,what are they?
Thanks for the info.
I've had many "Y"s over the years,a motor a like a lot an also raced for a time,was the first motor I picked to build a hotrod with back in 1959,so there are still 4 of them in the back my garage and one in my old hotrod,I don't remeber were they all came from,way too many all sizes,used up all the 312's years ago,would love to get another but there out of my piggybank $ now. Just had never payed any mind to these stamped# before.
Thread Tools
Display Modes
