Old 07-18-2013, 09:37 PM   #1
jhaas63
Default is this too hot for my flathead?
Like most parts of the country, it is terribly hot here in Wisconsin. It has been in the lower 90's with a ton of humidity. I just installed mechanical water temp gauges on my 1953 8rt in my 53 f100. On a recent trip of about 20 miles, i noticed the temp was just over 200. When I got it to my house, the overflow was dripping a few drops but nothing significant. Any cause for concern here?
jhaas63 is offline   Reply With Quote
Old 07-19-2013, 12:38 AM   #2
Old Henry
Old Henry's Avatar
Default Re: is this too hot for my flathead?
Other's may differ but, in my opinion, 200° is not approaching boil over at your elevation if you're using the standard 7 lb. radiator cap. At sea level atmospheric pressure of 15 psi water boils at 212°. But, adding the 7 lb. radiator cap raises the boiling point to 233°. You're still 33 degrees below that at 200°. If you keep your radiator full the mear expansion of water will push some out through the radiator cap and is not something I worry about. I leave the water down a bit in the radiator to allow for expansion of the water.
Prof. Henry (The Roaming Gnome)
"It is good to have an end to journey toward; but it is the journey that matters, in the end.” *Ursula K. Le Guin in The Left Hand of Darkness
Old Henry is offline   Reply With Quote
Old 07-19-2013, 06:39 AM   #3
richard crow
install a recovery take you can either buy one there cheap or make your own
richard crow is offline   Reply With Quote
Old 07-19-2013, 08:24 AM   #4
gmc1941
gmc1941's Avatar
Install a over flow tank and a 7lb cap and it will be fine.
1939 Fordor Deluxe
1939 Ford Coupe Std
1940 Ford pickup
Nothing in life is to be feared; it is only to be understood.
gmc1941 is offline   Reply With Quote
Old 07-19-2013, 10:18 AM   #5
Ken Bull
Ken Bull's Avatar
When I first ran my v8 --rebuilt Radiator etc-- I freaked out when steam was coming out of the hood vents , even had some antifreeze on the running board. When it cooled down the water level was 1/2" above the cores in the radiator & no more problem--The cooling system found the level it likes. (I think I have a 7lb Cap) One of these days I will put on a Recovery Tank like Richard Crow suggests, cause I'd like to think I have the 22 quarts in there the factory calls for. Living in Florida I run with no thermostats, Skips rebuilt Pumps & Coil . Hi Rich
Oh! I use some Purple Ice mixed in there too & according to my hand held Temp Gun I do 10 -15 degrees cooler
Ken Bull is offline   Reply With Quote
Old 07-19-2013, 10:22 AM   #6
Ross F-1
Ross F-1's Avatar
F-1's used a 4-lb cap.
'52 F-1, EAB flathead
Ross F-1 is offline   Reply With Quote
Old 07-19-2013, 03:28 PM   #7
jhaas63
I currently have a 4 lb cap...I take it I need to put on a 7 lb cap?
