Old 11-07-2020, 03:26 PM   #1
satfix
Default Recommended gear oil for Dana 44
I have a Dana 44 rearend on my 52 F1. I plan on changing the oil in it as I don't know when the last time it was changed.
What weight oil should I use? It's got a 3spd manual transmission. I live in South Carolina and don't tow anything; nor carry heavy loads.
thoughts?
Thanks
satfix is offline   Reply With Quote
Old 11-07-2020, 06:34 PM   #2
rotorwrench
rotorwrench's Avatar
Default Re: Recommended gear oil for Dana 44
Most all of the later Ford or Dana axles can use SAE 85W/90 or 85/W140 GL-5 gear lubricant of the high EP variety. It's available about anywhere you go and from multiple sources.
Transmissions are the ones that can have difficulty with high EP additives.
Old 11-07-2020, 06:49 PM   #3
satfix
Thanks!
