02-15-2016, 04:01 PM | #1 |
New Distributor Points for Model A
Has anyone used the new points from Standard? I only say new because I was just showed a set this week and hadn't seen them or heard anything about them. The part number on them is FD 1718 and the major change is the wear block is made of modern material. Otherwise I think they are just like the original? That's the main complaint for going with modern points over the past years? contact_set_oem_fd1718.jpg
02-15-2016, 05:34 PM | #2 |
Re: New Distributor Points for Model A
Very interesting, I didn't know these were available.
02-15-2016, 05:45 PM | #3 |
Flathead
I didn't know until last week one of our members asked if I had seen them. I said I wasn't aware of any new points and then looked at them. I googled that number online and they were all over. The one thing I noticed is the price is quite high I thought. I paid $12.00 and online they were anywhere from $29.00 - $15.00. I might start to build some distributors with these but will try to get the price down. |
02-15-2016, 07:36 PM | #4 |
I recently bought points from O'reilly ...was a little surprised that they had them..
BWD brand, but they look just like the Standard brand pictured above... http://www.oreillyauto.com/site/c/de...A123/02766.oap http://www.summitracing.com/parts/smp-fd1718 What would an original points set look like? The picture is of the BWD set being installed..
Early '29 CCPU that had a 4-speed, but not any more.......in the family since '62 Last edited by 1955cj5; 02-15-2016 at 08:31 PM. |
02-15-2016, 08:22 PM | #5 |
I use the standard points all the time I get them from my shop jobber...
The PN as mentioned is FD1718 The condenser is FD11 and have yet to have one fail...I think there's are short proof also |
02-16-2016, 11:30 AM | #6 |
02-16-2016, 11:51 AM | #7 |
Remember, QUICK & UNEVEN rubbing block wear can happen, if the pivot post for the point arm is LOOSE & WOBBLY! It can be tightened, under the plate, with a punch & a TAP-TAP-TAP! Both of mine were LOOSE as a GOOSE!
Bill Tap
