Old 04-24-2021, 01:11 PM   #1
justpassinthru
justpassinthru's Avatar
Default 1949 Ford pass car serial number locations
I know there is a serial number stamped in the right front frame horn near the cross member.
Are there any more stamped in the frame elsewhere like on earlier frames?
Bill
THIS ISN'T THE KIND OF ANSWER
I WAS LOOKING FOR OUT OF YOU!
justpassinthru is offline   Reply With Quote
Old 04-24-2021, 05:00 PM   #2
3quarter32
3quarter32's Avatar
Default Re: 1949 Ford pass car serial number locations
http://www.vanpeltsales.com/FH_web/f...9VINdecode.htm
3quarter32 is offline   Reply With Quote
Old 04-24-2021, 07:26 PM   #3
justpassinthru
Van Pelt only shows one on the body for 49 Ford. Does not reference any on the frame.
I have a 49 Two door sedan frame that has a serial number 98BAxxxxx, with stars at each end, stamped on the right front frame rail.
Not sure if there are serial numbers elsewhere on the frame, I can't see any at this time but would like to know for sure.
Thanks, Bill
Old 04-24-2021, 08:24 PM   #4
nelsb01
nelsb01's Avatar
Did you look behind the passenger side hood hinge?
There should be a data plate mounted there with the serial number.
That of course will be there if the vehicle is original or in untouched condition.
nelsb01 is offline   Reply With Quote
