Old 06-06-2020, 05:31 PM   #1
philipswanson
Default Stabbng the rear end with Columbia
I am installing the banjo rear end and spring assembly in my 40 wagon with a Columbia. Boy that's a heavy assembly. Any advise?
philipswanson is offline   Reply With Quote
Old 06-06-2020, 05:51 PM   #2
V8COOPMAN
V8COOPMAN's Avatar
Default Re: Stabbng the rear end with Columbia
Yeah.....don't try to lift it without help, or without a jack! DD
Click Links Below __
T5 W/TORQUE TUBE
Old 06-06-2020, 06:43 PM   #3
G.M.
Completley set up the rear with spring and drums. Jack car
up so top of spring clears fuel tank. Roll rear into U joint.
Not a big deal. G.M.
www.fordcollector.com
Old 06-08-2020, 01:22 PM   #4
philipswanson
Thanks all!
Old 06-08-2020, 07:44 PM   #5
glennpm
glennpm's Avatar
Put a good rolling jack or motorcycle/ATV jack under the "pumpkin". One hand on jack and the other on one of the axle half's and it move pretty easy. Put on jack away from car and push the whole assembly in to transmission and spring mount.
Old 06-09-2020, 09:01 AM   #6
uncle buck
uncle buck's Avatar
This , also I use a transmission jack with a larger saddle which seems to hold it more stable
uncle buck is online now   Reply With Quote
Old 06-10-2020, 08:21 AM   #7
john in illinois
john in illinois's Avatar
I use 2 floor jacks,one on each axle. Pump them up together and easy to control.
John
Welcome each day
john in illinois is offline   Reply With Quote
Old 06-10-2020, 01:18 PM   #8
Pete pa
I used a ratchet strap looped thru the rear bones mount on the torque tube, and looped around the shift tower, put the Columbia on one of the wheel dollies with some cribbing for height so I could guide the drive shaft in the u-joint. Works great.
Pete pa is offline   Reply With Quote
Old 06-10-2020, 02:22 PM   #9
philipswanson
That's a great idea. I jus happen to have one.
Old 06-10-2020, 02:26 PM   #10
philipswanson
Nomenclature problem. What is rear bones mount, shift tower ??? Can't picture this. Thanks anyway.
Old 06-10-2020, 03:15 PM   #11
Pete pa
The mount on the torque where the rear radius rods connect, and a shift tower is the part of the transmission where the floor shifter is mounted.
Old 06-10-2020, 08:34 PM   #12
philipswanson
No floor shift, its a 40. Got you on the mount on the torque tube. Thanks.
Thread Tools
Display Modes
