Old 12-12-2019, 09:25 PM   #1
Hal Beatty
Hal Beatty's Avatar
Default 1940 interior Door trim clips; not door panel clips
Anyone have a source for the clips that are used to attach the Door Pillar and Header Trim to the inside of the door? These are the upholstery covered sheetmetal panels that attach to the inside top of the doors on a '40 behind the window mouldings. I need a few more to finish my interior.
Hal Beatty is offline   Reply With Quote
Old 12-13-2019, 01:16 AM   #2
Gary Tosel
Gary Tosel's Avatar
Default Re: 1940 interior Door trim clips; not door panel clips
If these are wire type clips like those I used on my 36 Ford for that same application, then check with Restoration Specialties and Supply, Inc.
814-467-9842
They indicate in their ad that you need to provide dimensions of the clips you need and the hole size.
I would check there web site and then call to confirm.
Gary Tosel is offline   Reply With Quote
Old 12-13-2019, 01:17 AM   #3
deuce_roadster
deuce_roadster's Avatar
Try restorationspecialties.com
Their new catalog has more clips then their online website last time I looked.
Old 12-14-2019, 12:28 PM   #4
Hal Beatty
Hal Beatty's Avatar
Thanks guys... I had looked at their website and didn't see what I need. Will give them a call.
Old 12-14-2019, 04:55 PM   #5
Pete pa
Drake has them listed in his catalog 91a-20020-b 39 deluxe upper dash trim & interior upper door window trim panels.
Pete pa is offline   Reply With Quote
Old 12-14-2019, 06:08 PM   #6
Hal Beatty
Hal Beatty's Avatar
Pete... Thanks, those are the ones! I'll get them ordered.
