Old 11-05-2018, 09:01 AM   #1
ModelAJim
ModelAJim's Avatar
Default Cowl Width Dimension on Tudor or Coupe
Guys, I know this is picture of a Roadster cowl, can any of you tell me the dimension here? For a Tudor or Coupe? the seam where firewall meets the skin. I appreciate it Thanks!
File Type: jpg A-26-27-Model-T-Ford-Roadster-Pickup-_1.jpg (59.8 KB, 7 views)
ModelAJim is offline   Reply With Quote
Old 11-06-2018, 06:03 PM   #2
t42
Default Re: Cowl Width Dimension on Tudor or Coupe
Your photo is a little confusing. Where your arrows are located appears to be above the lowest part of the firewall. The sides are tapered in on that location. At the very bottom, the dimension on my '26 Coupe is 28-1/4" where the skin meets the firewall. Hope this helps.
t42 is offline   Reply With Quote
Old 11-07-2018, 07:00 AM   #3
ModelAJim
ModelAJim's Avatar
It does Thank you!!
