Old 06-17-2017, 03:52 PM   #1
coolcoupe
coolcoupe's Avatar
Default vacuum testing
To hook up a vacuum gauge, do I use the vacuum line that feeds the wiper and disturbutor that connects to the base of the carb ?
coolcoupe is offline   Reply With Quote
Old 06-17-2017, 03:55 PM   #2
Brian
Brian's Avatar
Default Re: vacuum testing
Yes, use the feed to the wipers
Unfortunately, two half wits don't make a whole wit!
Brian is offline   Reply With Quote
Old 06-17-2017, 03:57 PM   #3
coolcoupe
coolcoupe's Avatar
So I plug it right into the carb ?
Old 06-17-2017, 04:02 PM   #4
coolcoupe
coolcoupe's Avatar
What I meant to say was I plug it into the base of the carb without the other two connected.
Old 06-17-2017, 04:06 PM   #5
Ronnieroadster
Ronnieroadster's Avatar
You can leave both connected or just take a reading without them connected.
Using the base of the carb for the reading is the best location your reading will be highest at that point.
Ronnieroadster is offline   Reply With Quote
Old 06-17-2017, 07:20 PM   #6
coolcoupe
coolcoupe's Avatar
Thanks Guys
Old 06-17-2017, 11:35 PM   #7
Drbrown
Drbrown's Avatar
This may be slipping by .... but leave the metal tube distributor line connected to the carb base .... its usually soldered pending year/model set up. As Brian noted, just disconnect the rubber hose from the wiper connection.
Photo shows my '47 set-up. Distributor and wiper connections in lower-right center.
Drbrown is offline   Reply With Quote
Old 06-17-2017, 11:58 PM   #8
Brian
Brian's Avatar
Sorry, been out all day in my 35. The reason I use the wiper line is so that the distributor is still plumbed in. That'll give you a more accurate picture of what's going on.
Old 06-18-2017, 09:27 PM   #9
coolcoupe
coolcoupe's Avatar
Thanks Guys, I had not been to garage yet so will try that then.
Old 06-18-2017, 11:34 PM   #10
Drbrown
Drbrown's Avatar
If you haven't discovered this .... here's two good resources for understanding vacuum gauge readings.
http://www.secondchancegarage.com/public/186.cfm
Flathead Vacuum Question (http://www.fordbarn.com/forum/showthread.php?t=149754)
Old 06-19-2017, 11:48 PM   #11
coolcoupe
coolcoupe's Avatar
Thanks Drbrown
Old 06-20-2017, 07:06 PM   #12
russcc
That tutorial on vacuum readings was excellent. Now to find a good old working gauge.
russcc is offline   Reply With Quote
Old 06-20-2017, 11:18 PM   #13
Drbrown
Drbrown's Avatar
I got my vac gauge at AdvancedAuto several years ago and it seems to work fine. However, I've not had a serious problems since that purchase.
