08-07-2016, 12:31 PM | #1 |
charging
How can you test if the voltage regulator is letting the generator charge the battery ? I'm not sure about this voltage regulator. Thanks, Moe
08-07-2016, 12:49 PM | #2 |
Re: charging
There are numerous threads on this topic plus the service manuals have detailed charging system test.
08-07-2016, 01:31 PM | #3 |
Re: charging
The gauge in the car does not show any charge even at high revs but show discharge if I turn the lights on. How do I check the voltage regulator to know how much current is being send ?
08-07-2016, 03:01 PM | #4 |
Re: charging
Check the voltage at the battery, check it with the engine off (should be in the mid 6v range). Then check it at idle and around 2000 rpm (should check in the mid to upper 7v range above idle). Now check it with the headlights on. What are you getting?
The voltage out of the regulator is the B terminal, but it is better to check it at the battery. |
08-07-2016, 06:24 PM | #5 |
Re: charging
Moe, You asked questions a week ago about this and I explained how to check the voltage at the regulator so did you do that ? What was the voltage at the "ARM" or the "BAT" terminal on the regulator with the engine up at 2000 rpm ? Should be around 7.5 volts. If you cant do that then take your car to an auto electrical shop for them to check it out. You said some rodents chewed up the generator wiring so was this repaired correctly ? Regards, Kevin.
08-07-2016, 11:06 PM | #6 |
Re: charging
On my trip to Alaska in May my generator quit charging. I was pretty sure it was the brushes worn or wearing out. I had spares but really didn't want to take the time to remove the generator and disassemble it to replace the brushes. So, I just whacked the generator up one on the side to loosen the brushes that were stuck in their holders and get them back down on the commutator. Worked like a charm. Generator ran fine for the rest of the trip and has continued ever since. Might try a hammer for a quick (albeit likely temporary) fix.
Prof. Henry (The Roaming Gnome) "It is good to have an end to journey toward; but it is the journey that matters, in the end.” *Ursula K. Le Guin in The Left Hand of Darkness Last edited by Old Henry; 08-07-2016 at 11:33 PM. |
08-07-2016, 11:11 PM | #7 | |
Re: charging
Your gauge indicates no charging at all. The regulator doesn't send "amounts" of current to the generator. It is just a switch that turns the current to the field coil on the generator on and off depending on the voltage and amps being put out be the generator. If you really suspect the regulator, bypass it by jumping from the bat terminal on the regulator (or battery post) to the field coil on the generator and see if you get any increase in voltage at the battery terminals. If not, it's a bad generator. Most likely simple brush replacement and you're good to go. P.S. Love your avatar . . . a lot!
Prof. Henry (The Roaming Gnome) "It is good to have an end to journey toward; but it is the journey that matters, in the end.” *Ursula K. Le Guin in The Left Hand of Darkness Last edited by Old Henry; 08-07-2016 at 11:39 PM. |
08-07-2016, 11:17 PM | #8 |
Re: charging
Here are a couple of diagrams from the Ford Generating and Starting Systems Repair Manual that helped me a lot to figure out how the charging system worked and where it wasn't working.
$14.00 here: http://www.ebay.com/itm/Ford-Repair-...pXpJkq&vxp=mtr Well worth the education.
Prof. Henry (The Roaming Gnome) "It is good to have an end to journey toward; but it is the journey that matters, in the end.” *Ursula K. Le Guin in The Left Hand of Darkness Last edited by Old Henry; 08-07-2016 at 11:36 PM. |
08-08-2016, 06:48 PM | #9 |
Re: charging
[QUOTE=Old Henry;1335663]Your gauge indicates no charging at all. The regulator doesn't send "amounts" of current to the generator. It is just a switch that turns the current to the field coil on the generator on and off depending on the voltage and amps being put out be the generator. If you really suspect the regulator, bypass it by jumping from the bat terminal on the regulator (or battery post) to the field coil on the generator and see if you get any increase in voltage at the battery terminals. If not, it's a bad generator. Most likely simple brush replacement and you're good to go.
Old Henry & Moe, The above instruction for testing if the generator is working with the regulator bypassed (except for the cut out) is not quite correct. On the Ford system remove the generator field wire from its terminal on the regulator and move it across and connect it to the "ARM" terminal on the regulator. This will bypass the voltage and current controls in the regulator but leave the cut out to operate as normal. Start the engine and rev it up to around 2000 RPM and observe your dash ammeter or battery gauge (voltmeter) on some models. You should have a very high reading here because the generator is uncontrolled. If there is no charge then more than likely the generator is at fault, or a wiring or cut out problem. Moe, test that and see what happens. Regards, Kevin. |
08-09-2016, 12:05 PM | #10 |
Re: charging
Thanks, koates ,Henry, JSeery I finally had time to work on it today. Last night
a buddy of mine suggested I try his spare and when I did everything worked as before !!! So this chipmunk must have screw it up. Good ending. But I have made a copy of all the repondes for future reference. Thanks again for the patience. |
08-09-2016, 08:43 PM | #11 |
Re: charging
Moe, Try a spare what ?? Generator or regulator. Have you checked the voltage with engine revs up. After all our input, don't leave us all hanging ! What fixed it ? Regards, Kevin.
08-09-2016, 10:30 PM | #12 |
Re: charging
Me too, did you swap the generator?
Thread Tools | |
Display Modes | |
