Old 05-23-2021, 08:26 PM   #1
Dave1931Pickup
Default B Distributor Cam
Is a B Distributor Cam the same as the A Distributor Cam?
Thanks, Dave
Dave1931Pickup is offline   Reply With Quote
Old 05-23-2021, 08:42 PM   #2
Bob C
Default Re: B Distributor Cam
No.
Old 05-23-2021, 08:59 PM   #3
jb-ob
Nope, Improved profile to give longer dwell, better coil saturation = hotter spark at your plugs.
Enjoy the ride.
jb-ob is offline   Reply With Quote
Old 05-24-2021, 05:50 AM   #4
Patrick L.
Patrick L.'s Avatar
I believe all that is available now they the vendors is the 'B' cam because of its different [ better dwell angle] profile.
Old 05-24-2021, 10:07 AM   #5
katy
katy's Avatar
But they are interchangeable.
If you put in a new B cam, check the finish of the surface.
I put a new one in a few years ago, expecting it to be A OK and it wasn't. The surface was quite rough and wore down the rubbing block of the points in a very short time.
The manufacturers may have improved them by now, it would be wise to check a new one to be sure of it's finish.
One can see the rough finish in this photo:
Old 05-24-2021, 10:22 AM   #6
Benson
Benson's Avatar
For those who do not know this:
I see from this photo that the points are REPRO.
Points made for the last several years are too long and do not lineup as seen in the photo.
Berts has two versions of the blocks for sale.
One original and the second one to fix this problem.
A-12160 is original point block for original point sets.
A-12160-B is version for long points.
click here to see both types:
https://modelastore.com/index.php?ro...&category_id=0
Read description for details.
Here is page for both point sets:
NOTE The new block set will not work with upper plate in the photo because block is not removable in this case.
Old 05-24-2021, 10:23 AM   #7
JayJay
I put in a new B dist cam a few weeks ago and found it to be sort of smooth, but not what I expected. Had to spend a few minutes with fine paper and emery to get it right.
JayJay
JayJay
San Francisco Bay Area
1930 Murray Town Sedan
1931 Briggs S/W Town Sedan
Old 05-25-2021, 09:59 AM   #8
katy
katy's Avatar
After that photo was taken I replaced the upper plate w/a new one w/the detachable mount for the stationary point. The points still didn't line up so I filed the holes where the mount attaches to the plate to allow adjustment of the mount. I also smoothed out the surface of the cam.
The original points were still good, other than the worn out rubbing block, so I replaced the rubbing block w/a homemade one.
Old 05-25-2021, 10:20 AM   #9
The Master Cylinder
The Master Cylinder's Avatar
Bratton's has a very nice machined points block. https://www.brattons.com/machined-di...int-block.html
The Master Cylinder
Enjoying life at the beach in SoCal...
The Master Cylinder is online now   Reply With Quote
Old 05-25-2021, 01:12 PM   #10
Greg Jones
Greg Jones's Avatar
Even with the modified point block, it still takes some fussin' to get it to fit half-way correctly and have the points close squarely. If these points are going to be made incorrectly forever, then perhaps the vendors might consider making a modified upper plate so that the point block fits correctly. Wallowing out the holes to make the point block fit is not a real good solution. My two cents.....
Greg Jones is offline   Reply With Quote
