08-16-2019, 03:31 PM | #1 |
Optima battery support bracket/carrier for a '34
Given that the Group 2LF battery is no longer available and the Optima 6 volt battery is now taller, I'm looking for a underfloor battery support bracket/carrier to replace the stock Group 2LF carrier in my '34 - a carrier that will accommodate the taller 6 volt Optima battery. Ideally this carrier will mount the Optima vertically using the same mounting bolts & holes as the original battery support bracket. I don't want to drill additional holes or make other modifications other than replacing the original bracket/holder and I don't want to relocate the battery to the firewall. If any of you have done this, please post pictures of your underfloor installation....
08-16-2019, 03:53 PM | #2 | |
Re: Optima battery support bracket/carrier for a '34
www.fordcollector.com |
08-16-2019, 04:11 PM | #3 |
I made a carrier that is a duplicate of the original, except made a hair taller for the Optima. No pictures, but be assured, it looks like original except for the height dimension. Are you willing to accept that it hangs lower?
08-16-2019, 04:28 PM | #4 | |
A carrier to accommodate the taller Optima would only hang about an inch lower than the original bracket which is of no concern to me. I do have a NOS original bracket I could modify but I'd rather have a bracket that fits the Optima's dimensions. I'm searching to find someone who could custom make a battery carrier to meet my needs. ...
08-16-2019, 06:41 PM | #5 |
JM 35 Sedan has done what you're lookinh for. Search his past posts, he's done pics.
-Jeff H Have you thought about supporting the Early Ford V-8 Foundation Museum? |
08-16-2019, 08:46 PM | #6 | |
Thank you, Jeff, but I've seen JM's adaptation for his '35 and it is not applicable to what I want for my '34 in that he mounts his Qptima battery horizontally. I want to be able to drop the battery into place from above through the floorboard as is normal for a '34....
08-16-2019, 11:57 PM | #7 | |
08-17-2019, 02:11 AM | #8 |
Checked and you're right. It was someone else's '35....Battery mounting in a '35 is entirely different than in a '34....
08-17-2019, 07:22 AM | #9 |
This is not mine but it looks good. Modify size to fit.
08-17-2019, 09:02 AM | #10 |
I really like that bracket Terry, thanks for posting it.
08-17-2019, 01:23 PM | #11 |
This stainless steel box on eBay shows some potential > https://www.ebay.com/itm/NEW-DROP-OU....c100033.m2042
Overall Dimensions: 11 1/4" Wide, 7 3/4" Deep, and 9 1/4" Tall
The only thing nice about being imperfect is the joy it brings to others.... "Silver rings, your butt! Them's washers!" "We shot our way out of that town for a dollar's worth of steel holes!" - from 'The Wild Bunch' - 1969 https://www.youtube.com/watch?v=7NReUd2_0u0 Last edited by petehoovie; 08-17-2019 at 02:05 PM. |
