Old 03-08-2014, 01:57 PM   #1
Steve Miller
Steve Miller's Avatar
Default Generator smoking
I hooked up the battery today (new one) for the first time, positive ground. Turned the cut off switch to on and the horn blows constantly. Turn back off and disconnect horn, will fix the stuck button later. Turn the switch back on lights work, great, but the ammeter is discharging at -20 and I'm getting smoke out the back of the generator. Turned switch back off, disconnected battery cable.
I have not rebuilt the starter or replaced the cut out and have not had them apart, don't know about the last guy that owned the truck. Could this be the generator cut out stuck, will the open circuit on the horn cause this, or is it something else?
Thanks
Steve Miller is offline   Reply With Quote
Old 03-08-2014, 02:48 PM   #2
Purdy Swoft
Purdy Swoft's Avatar
Default Re: Generator smoking
Probably the points stuck in the cutout.
Old 03-08-2014, 11:44 PM   #3
Mike V. Florida
Mike V. Florida's Avatar
Smoke not good!
Old 03-09-2014, 07:18 AM   #4
chopo
take away its lighter
www.jalopyshowdown.com
dont scare me i poop easy
chopo is offline   Reply With Quote
Old 03-09-2014, 07:26 AM   #5
crumbaa
crumbaa's Avatar
That does not sound good, nothing worse than leaky smoke valve.
Seriously, I sure how it works out.
If it was easy everyone would be doing it
/Tony
crumbaa is offline   Reply With Quote
Old 03-09-2014, 09:29 AM   #6
Patrick L.
Patrick L.'s Avatar
I'm with Purdy. If you loosen or remove the belt does the generator motor ? If it does, there may not be anything wrong except the cut-out [ which should be able to be fixed]. If it doesn't then there is probably something wrong with both cut-out and generator.
Old 03-09-2014, 09:31 AM   #7
John LaVoy
John LaVoy's Avatar
When you let the smoke out the generator quits working.
John LaVoy is offline   Reply With Quote
Old 03-09-2014, 06:17 PM   #8
Steve Miller
I didn't try to start it yet so the generator never even had a chance to turn
Old 03-09-2014, 06:32 PM   #9
super flat
super flat's Avatar
OK maybe a dum question, but 6 or 12 volt, did you just get the vehicle, and maybe its coverted to neg ground?
I am usually relatively happy------Gary
super flat is offline   Reply With Quote
Old 03-09-2014, 08:10 PM   #10
Steve Miller
6V, had it since '06 and as far as I know it was never converted to neg ground
Old 03-09-2014, 08:59 PM   #11
sethkestenbaum
sethkestenbaum's Avatar
.... at least it isn't also drinking. (ok, that wasn't helpful)
Seth Kestenbaum
www.oldcarroadtrip.com
sethkestenbaum is offline   Reply With Quote
