Old 07-27-2017, 07:14 PM   #1
Vic in E-TN
Question '35 Front Wheel Bearings
Does anyone have the front wheel bearing numbers (Timken) or otherwise for the inner and outer bearings for the front wheel? If you have the outer/inner diameter for these, it would be helpful also. I am looking to purchase a pair of '35 spindles to use on a trailer and fit some Model A hubs to them.
I do not have any early V-8 catalogs, only Model A information.
Thanks,
Vic
Vic in E-TN is offline   Reply With Quote
Old 07-27-2017, 07:32 PM   #2
barnstuf
Default Re: '35 Front Wheel Bearings
Your Model A information will work as wheel bearings and races 1928 thru 1948 are the same.
barnstuf is offline   Reply With Quote
Old 07-27-2017, 08:49 PM   #3
Vic in E-TN
Good. I was hoping so.
Vic
