03-30-2022, 07:31 PM | #1 |
Brake Light Switch
Does anybody know if a 30-31 brake light switch can be made to work on a 29?
03-30-2022, 08:08 PM | #2 |
Re: Brake Light Switch
They mount and actuate differently. Thats not to say it can't be done, but why?
03-30-2022, 08:36 PM | #3 |
My 29 had a 30-31 style brake switch installed.
They went through the trouble of cutting holes in the frame crossmember to mount the switch and altering the pedal to cross shaft rod so it would work like a 30-31 style. I suppose they used what they had but I removed it and installed an original type repop switch.
Early '29 CCPU that had a 4-speed, but not any more.......in the family since '62 |
03-31-2022, 04:30 AM | #4 |
If you switch to the 30-31 style switch buy the more expensive "quality" switch. The cheap ones are junk.
04-01-2022, 03:59 PM | #5 |
The 28/29 switch is generally more reliable than the later type.
04-05-2022, 05:58 AM | #6 |
Looking for an unrestored 33 34 3W or 5W coupe. Thanks |
