Old 01-19-2019, 05:46 PM   #1
Al 29Tudor
Al 29Tudor's Avatar
Default Best head gasket
Hi Gents,
Blew my head gasket on a tour yesterday and I'd like some comments on the head gasket made by Best performs.
Bratton's catalog describes it as Kevlar reinforced graphite facing material bonded to a perforated steel core.
If anyone has first hand information I'd like to hear it.
Thanks for your help.
Al
Al 29Tudor is offline   Reply With Quote
Old 01-19-2019, 06:46 PM   #2
Y-Blockhead
Y-Blockhead's Avatar
Default Re: Best head gasket
Never had a problem with the Best Graphtite head gasket. Do retoque your head after running and cooling 2-3 times.
Old 01-19-2019, 06:56 PM   #3
Ernie Vitucci
Good afternoon...Also remember to re-torque your head once a year. Occasionally you will find a nut that takes 1/8 turn or so...much less work than changing a head gasket...Ernie in Arizona
Ernie Vitucci is offline   Reply With Quote
Old 01-19-2019, 09:46 PM   #4
Gary WA
Gary WA's Avatar
My take Copper Only! I have had 3 graphite fail with proper torques,flat head and block. I just don't care for them,But that's me.
www.whidbeymodelaclub.com
Old 01-20-2019, 12:42 PM   #5
Jim Brierley
Racers that I know use the Best graphite gasket and report it is the best. Best also makes a copper gasket under the same number. I prefer copper, they are easier to change if needed. Always re-torque as stated above.
Jim Brierley is offline   Reply With Quote
Old 01-27-2019, 12:16 AM   #6
Dodge
And just when you think you've torqued it enough times, torque it again.
I really like the Best Graphfite gaskets.
Dodge is offline   Reply With Quote
