Old 01-13-2019, 08:41 AM   #1
Al 29Tudor
Al 29Tudor's Avatar
Default Replacement shocks
Good morning,
I'd like to know what replacement shocks are available for my 29, Tudor. Currently my shocks are knock-off's designed in the 60's to look like original. They are shot so I don't have rebuildable cores.
I've read that there is a shock that will bolt up to the chassis and work well for a lot less than $1,000. The car is pretty much original and I won't use tube shocks.
Any leads on this?
Thanks,
Al
Al 29Tudor is offline   Reply With Quote
Old 01-13-2019, 09:52 AM   #2
Werner
Werner's Avatar
Default Re: Replacement shocks
Hello,
I have the same problem. All original shock adsorbers are defective. It's not possible to repair them.
New rebuilt like original are at this time not on stock by Snyders an Macs.
The tube absorber are not allowed in Germany.
Werner
Ford Model A, Roadster, 1928
Citroen 11 CV, 1947
Hercules W 2000, 1976; (with NSU-Wankel Rotary Engine), Canadian version
Werner is offline   Reply With Quote
Old 01-13-2019, 10:09 AM   #3
HD Rider
Not under a $1000 but these are the best I've found.
http://www.specialtymotorcams.com/shop.php
HD Rider is offline   Reply With Quote
Old 01-13-2019, 10:17 AM   #4
Kahuna
Kahuna's Avatar
Use MGB rear shocks
Kahuna is offline   Reply With Quote
Old 01-13-2019, 08:34 PM   #5
Penthode
Penthode's Avatar
Originally Posted by Werner View Post
..... It's not possible to repair them...
Why do you say it is not possible to build them? I saw an article where the old shocks were repaired.
Penthode is offline   Reply With Quote
Old 01-13-2019, 10:59 PM   #6
Mike V. Florida
Mike V. Florida's Avatar
Originally Posted by Al 29Tudor View Post
Good morning,
Any leads on this?
Thanks,
Al
First we have original. Small amount refundable, larger amount just rusted junk where no parts at all are good and a larger amount in the middle.
A) The Junk ones are just that!
B) While economical rebuilding of shocks can be done IF the shocks presented are within specifications.
C) The vast majority of shocks out there can be rebuilt. Before you hit the reply button to say otherwise read on. These need sleeves, lathes, mills, welders etc. To pay someone to build these would cost way, way more then anything new. BUT if you have the equipment, maybe you are retired with time on your hands and would do the work "just to do something" you can help out the model A owner.
After market,
A) The most original working Shocks are sold by Stipes. These are made and work just like originals and I've been told you can use original parts on these if you want. They are made in the USA and are the most expensive.
B) There are two other redesigns. They look like the original shocks to the casual observer but share nothing else. Snyders and Brattons, if I remember correctly are the ones having these made.
C) Tube shocks, there are several designs for sale some you drill holes in the car parts other you do not. Consensus is that you need to find oil filled shocks as gas filled shocks are too stiff.
