Old 05-15-2023, 02:54 PM   #1
CatMan1
Default Leaking Gas Valve
The interior gas valve must be leaking. When I shut it off the car will run out of gas and die, but later, a day or two, I can smell gas and see some on the floor. This valve probably isn't the original, but I don't know. Is it possible that after a few years these can go bad?
CatMan1 is offline   Reply With Quote
Old 05-15-2023, 03:06 PM   #2
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
Default Re: Leaking Gas Valve
It has been my experience that the only thing that causes them to leak as you are suggesting is when some foreign media (dirt, sand, rust, grit) enters the valve and scores the housing or the stem. When there is rust or grit present, it will continue to happen no matter how often you replace the valve. Even an aftermarket stainless ball valve will also leak when the grit is present.
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 05-15-2023, 03:09 PM   #3
Y-Blockhead
Y-Blockhead's Avatar
CatMan, there was a recent discussion on the subject. https://www.fordbarn.com/forum/showthread.php?t=325994.
There have been numerous posts about leaking S/O valve
Old 05-15-2023, 03:36 PM   #4
CatMan1
Looks like I'll be looking to put a new one on sometime. Say, where I work we sell X-Pando sealant. Anyone ever try this? Does it work well?
Old 05-15-2023, 03:42 PM   #5
nkaminar
nkaminar's Avatar
This works: https://www.aircraftspruce.com/catal...ezturnlube.php
Old 05-15-2023, 05:30 PM   #6
Synchro909
Synchro909's Avatar
It's quite a few years now since I used one of those Snyders kits to repair a leaky valve on my car. I was fascinated by the lubricating "grease" they supplied in a capsule. I strongly suspect the grease did not only lubricate the valve but it filled any irregularities/scratches in it.
I got to wondering what the grease was. It had to be fuel proof and lubricate. Everything I tried was dissolved by the petrol (gas), even silicone grease. Where else is a water soluble lubricant used I asked myself. Then it hit me.
Wait for it.....
KY jelly.
I haven't tried it (not sure I want my wife to find it!) but I bet some of that will help a leaky valve. Maybe a light lapping with toothpaste first, then a little KY.
Old 05-16-2023, 11:35 AM   #7
Floats
Floats's Avatar
Tks
Regards
Chris
Cape Town
28 Model A RPU, 29 Chevy Phaeton, 67 E Type FHC, 67 250SL Pagoda, 83 911 SC
Floats is offline   Reply With Quote
Old 05-18-2023, 10:14 AM   #8
katy
katy's Avatar
Wait for it.....
KY jelly. I haven't tried it (not sure I want my wife to find it!) but I bet some of that will help a leaky valve. Maybe a light lapping with toothpaste first, then a little KY.
Red rubber grease is impervious to gasoline, see: https://www.greasemonkeydirect.com/b...rease-used-for
