05-28-2015, 04:24 PM | #1 |
Source for PPG Concept paint?
Hello,
I need one more quart of PPG DCC-9300 black paint, so I called my usual source, TCP in San Diego. The told me that they have stopped carrying the PPG Concept single-stage paints. Does anyone know of an alternate source for this? I would hate to switch paint for just one front fender... Thanks, Doug
My '31 S/W sedan project:http://31ford.dougbraun.com My restoration diary: http://dougbraun.com/blog |
05-28-2015, 04:33 PM | #2 |
Re: Source for PPG Concept paint?
I buy my Concept at the local Carquest Auto parts store here in MN. I have heard that CA is mandating water based paints. I suspect soon all states will follow CA's lead and we will all be stuck with water based paint.
Rusty Nelson |
05-28-2015, 04:38 PM | #3 |
OR R.W.Mallon on rt 611, Warrington, Pa. I don't know if it's "Concept" but It's PPG.
Ph Number is 215-491-7234 Terry Last edited by Terry, NJ; 05-28-2015 at 09:28 PM. |
05-28-2015, 05:26 PM | #4 |
I just bought a gallon of DCC-9300 with hardner here in San Diego from a local PPG dealer. They have factory mixed colors such as black but no mixed colors. I was surprised that I could get it from them and was prepared to drive to Phoenix to buy it. They had us sign a statement that we were not a commercial shop but using it for personal use.
05-28-2015, 05:37 PM | #5 |
Concept is being phased out I understand by PPG. What replaces it I don't know. I have used Restoration Shop single stage urethane from AutoColorLibrary on several cars including two model As. Much cheaper that is for sure!
05-29-2015, 07:15 PM | #6 |
05-29-2015, 07:54 PM | #7 |
PPG concept paint is being fazed out..the best source I have found for matched model a paint is TCP globle good prices also...
The only thing worth learning is what you learn after you know it all !! |
05-29-2015, 08:12 PM | #8 |
Thanks for the leads.
I used TCP's "Restoration Shop" products when I painted my Triumph Spitfire a couple of years ago, and I was happy with them. But my "A" is already 80% painted with Concept, and I wouldn't want to see a color mismatch on it. Doug
05-29-2015, 10:35 PM | #9 |
TCP can match your paint.
05-30-2015, 12:51 AM | #10 | |
I have read about Concept being discontinued for about 4 years now. You really need to find all you need ASAP. See Brents post below
What's right about America is that although we have a mess of problems, we have great capacity - intellect and resources - to do some thing about them. - Henry Ford II Last edited by Mike V. Florida; 05-31-2015 at 12:42 AM. |
05-30-2015, 01:21 PM | #11 |
I have used both TCP product an PPG Concept. There is definitely a difference in quality of both products. Concept sprays out better with less coats needed. TCP needs more coats to cover. Concept sets up faster and is definitely more durable after it is dry.
05-30-2015, 01:41 PM | #12 |
05-30-2015, 10:42 PM | #13 | |
Doug
05-30-2015, 11:44 PM | #14 |
As of about a month ago, my PPG rep told me there were not immediate plans to drop the DCCline however at some point there would be lines that will replace it as far as popularity. The reason the DCC is so expensive is because there are heavy metals in the pigments that drive up the costs. I would have no problem buying paint from my jobber and shipping it to someone.
06-05-2015, 11:24 AM | #15 |
I had to drive down to Jackson California Amador County to buy some PPG DMC 921 black because they can no longer sell in EL Dorado county same paint store . I think the price has gone up also $ 113 .88 for a quart and $ 46.60 for 8 OZ DCX61 High Solids Urethane hardener . I needed some primer also $ 66.75 for a quart of DP50LF plus catalyst $ 38.45 and a gallon of reducer $ 65.40 Total $ 357.57 with tax OUCH .
Dennis in Kelsey ca |
