Old 09-11-2013, 06:36 PM   #1
crock
crock's Avatar
Default Disconnect switch
Have purchased a disconnect switch for my a. I have converted to 12volt negative ground. Should i switch the neg. Or pos. Cable?
MY PROBLEM CHILD!
crock is offline   Reply With Quote
Old 09-11-2013, 06:41 PM   #2
bbrocksr
Default Re: Disconnect switch
Negative
Bill
bbrocksr is offline   Reply With Quote
Old 09-11-2013, 07:28 PM   #3
Joe/Ct
Joe/Ct's Avatar
Originally Posted by bbrocksr View Post
Negative
Bill
Agree
Joe/Ct
"The older I get, the better I was"
Joe/Ct is offline   Reply With Quote
Old 09-11-2013, 09:05 PM   #4
H. L. Chauvin
Different opinions here at different times; however, please search on line.
A few disconnect "manufacturers" recommend installation details.
For peace of mind, please read what disconnect "manufacturers" recommend.
Then "you" make the decision.
H. L. Chauvin is offline   Reply With Quote
Old 09-11-2013, 09:48 PM   #5
Mitch//pa
place it in the negative and the reason being is that if any of the cables going to the switch was to ever suffer a rub thru or contact with a ground it wont short out and burn. just like if your removing the battery cable ends remove the neg first then the pos. reason being if your wrench hits a ground when disconnecting the pos first while the neg is still on it will create a firework. real world answers.
this is info for your 12v neg system
Old 09-12-2013, 01:13 AM   #6
H. L. Chauvin
FWIW:
Appears everybody thus far is agreeing with all of the vehicle & marine disconnect manufacturer's recommendations that I have read; i.e., place disconnect on the battery's ground cable for various different reasons.
Hope this helps.
Old 09-12-2013, 07:08 PM   #7
crock
crock's Avatar
thanks for the help. negative it will be.
MY PROBLEM CHILD!
