Old 06-09-2021, 09:10 AM   #1
alexiskai
alexiskai's Avatar
Default Filler putty for aluminum intake?
I've acquired a basic aluminum downdraft intake. There is a small divot in one of the mating surfaces that I would like to fill. If this were cast iron, I'd use JB Weld ExtremeHeat, but since it's aluminum I'm unsure what to use. Can anyone recommend a product that's both suitable for the purpose and inexpensive (since I'll probably only need it once or twice)? I'm thinking some kind of metallic paste or epoxy.
Old 06-09-2021, 10:04 AM   #2
Jerry in Shasta
Jerry in Shasta's Avatar
Default Re: Filler putty for aluminum intake?
Take a look their gaskets. Pricie, but they work
http://catalog.remflex.com/default.asp
Connoisseur of Rust
Jerry in Shasta is offline   Reply With Quote
Old 06-09-2021, 10:15 AM   #3
katy
katy's Avatar
A picture would be nice.
Old 06-09-2021, 10:19 AM   #4
alexiskai
alexiskai's Avatar
Thanks, I'll bookmark that.
Will provide one tonight. The intake is one of Tod's as shown in this post. It's one of the ones he mentions with "very minor issues."
Old 06-09-2021, 10:48 AM   #5
JayJay
Alexiskai - silly question, I know, but have you considered having the divot filled with weld material, then having the mating surface decked? A good machine shop should be able to do both in-house. With aluminum decking is a good practice against leaks anyhow. True, it will be more expensive than filling with something, but that way you'll know it's done right and is permanent.
JayJay
JayJay
San Francisco Bay Area
1930 Murray Town Sedan
1931 Briggs S/W Town Sedan
Old 06-09-2021, 10:53 AM   #6
alexiskai
alexiskai's Avatar
JayJay
I thought about it, it kinda seems like overkill. Particularly for this type of intake, which doesn't bolt to the exhaust and thus doesn't have to be milled flat relative to it. But I'd consider it if other options don't pan out.
Old 06-09-2021, 11:13 AM   #7
JayJay
You may not need the intake manifold true relative to the exhaust manifold (like the stock manifolds), but you do need the two intake ports true relative to each other (I presume the divot is on the engine mating surface, not the carburetor mating surface).
JayJay
JayJay
Old 06-09-2021, 11:18 AM   #8
alexiskai
alexiskai's Avatar
JayJay
Correct. Now that you mention it, I guess I will need to check it against the manifold I plan to use it with, because the thickness of the ears needs to be close on each one or the washers won't exert equal clamping force. And I should check it with a precision straightedge at the same time.
Old 06-09-2021, 12:22 PM   #9
jak
looking for something else and stumbled on this product.
https://www.2daydeliver.com/product_...cts%20MAIN%202
jak is offline   Reply With Quote
Old 06-09-2021, 12:31 PM   #10
alexiskai
alexiskai's Avatar
I found that in my research, but I wasn't sure how it would fare at high temperature.
Old 06-09-2021, 04:02 PM   #11
dave hummell
We used lab-metal to correct problems with defects when things were powder coated parts are heated to 375.
dave hummell is offline   Reply With Quote
Old 06-09-2021, 04:12 PM   #12
old31
Looks like good stuff.
https://www.jdindustrialsupply.com/labmetal6ozcan.html
https://www.jdindustrialsupply.com/h...yABEgJ4lvD_BwE
old31 is offline   Reply With Quote
Old 06-10-2021, 07:05 AM   #13
Pdgx
Pdgx's Avatar
Used this stuff frequently. As long as it’s clean, it will stick and doesn’t seem to be affected by engine heat.
It sets hard and you can drill, mill, file, etc.
File Type: jpg 06A8B441-701A-40DB-BBD4-A8E9186511F2.jpg (32.9 KB, 15 views)
Pdgx is offline   Reply With Quote
Old 06-10-2021, 07:29 AM   #14
Jack Shaft
Automotive RTV compounds, like permatex ultra will withstand the heat and fill the void, provided the void is captured.
Keeping the original exhaust manifold is a good idea, you need the heat transfer to prevent icing.
Old 06-10-2021, 08:54 AM   #15
alexiskai
alexiskai's Avatar
I wrote to JB Weld and they recommended using the original epoxy, which is good up to 550°. So I think I'm gonna go that direction since I already have that.
I'm planning to use an original manifold, but this intake doesn't have the transfer plate, so it'll have to be via convection and radiation instead.
Old 06-13-2021, 05:44 AM   #16
ronn
why switch, when you already have a good product?
I used JB in a heater that had indirect flame, but got quite hot nonetheless.
that and a quarter repaired the jet.
Old 06-13-2021, 01:59 PM   #17
alexiskai
alexiskai's Avatar
As promised, picture. I mentioned above that I'm gonna try JB Weld for the repair, so we'll see how it goes.
Old 06-13-2021, 05:06 PM   #18
Aretino
Aretino's Avatar
Used to use Devcon F in the aviation maintenance industry.
Aretino is offline   Reply With Quote
Old 06-13-2021, 07:41 PM   #19
Synchro909
Synchro909's Avatar
I'd try a small dab of silicone on that divot. Vacuum will hold it in place if vacuum reaches it, it is flexible and withstands temperatures way in excess of what you will get on an inlet manifold. Heck, I've seen no manifold gaskets at all (exhaust included) on a Model A, just silicone and the car ran like a champ.
Don't over think it.
Old 06-13-2021, 10:57 PM   #20
Jack Shaft
There is enough support to just to run a gasket.
