03-22-2015, 03:29 PM | #1 |
Need to clean NOS Ford cadmium bearings
What works the best for cleaning NOS dirty, oxidized engine bearings.
03-22-2015, 03:59 PM | #2 |
Re: Need to clean NOS Ford cadmium bearings
The race guys (on modern bearings) often scuff them with a pad, so that might work.
03-22-2015, 04:32 PM | #3 |
The first thing to think about is how badly are they oxidized? If they truly are pitted, then I wouldn't run them . . . find other sets. Yes, I know they're expensive and hard to find, but if the bearing surfaces are compromised, then they will build up heat - which is what ruins bearings and journals.
If you believe they are good, then use a fine pad of 3M Scotchbright and lacquer thinner. You should just lightly scuff/polish them - you should not be trying to remove pits due to oxidation. Once I'm done with this, then I use a very fine paint polish (for clear coats) and a cotton rag and hand polish them as much as possible. If these are rod bearings for full-floaters, then you need to prep both sides. If you're setting up full-floater rods/bearings, then you also need to "tune" the bearings to they are concentric in the rod bores and float between the rods and crankshaft as they should. This involves a big rubber hammer and a block of wood - and knowledge and patience. If you want me to check them out - drop me a few close-up and in-focus pictures. Good luck, B&S Last edited by Bored&Stroked; 03-23-2015 at 07:19 AM. |
03-22-2015, 04:51 PM | #4 |
what I did with the ones in my pile was to clean them with oil and a rag. then oil them up and wrap each one in an oiled paper towel then into the box,real messy to do but I feel better with them stored this way.
Lawrie |
03-22-2015, 05:27 PM | #5 |
Or how about immersing them in a plastic paint can or mason jar filled with oil? Then put a lid on it. Like I do with my saw chains.
Jack E/NJ |
03-22-2015, 05:34 PM | #6 |
03-23-2015, 07:23 AM | #7 | |
Okay, enough of my BS: That won't hurt them a bit, but you should coat them with something to prevent rust. I buy the cans of spray white lithium grease and coat both sides and wrap them in paper towels and then put them in a plastic zip-loc bag. You don't want them banging around into each other - so putting the bag in a box is a good idea as well. |
03-23-2015, 07:54 AM | #8 |
When using Floating bearings, I like to use, Used ones that measure OK. I have found that under racing conditions the NOS have a tendency to flake, and was one of the reasons we went to full flow oil system along with reducing oil pressure. This all took place over several years, as we learned more about the bottom ends. We also increased the OD of the Rod .001/.002" over stock. Tried to keep the oil pressure below 50 lb max. After a years we could run a season on them. Theses were never balanced and ran Janns Pistons, turning over 5K every night. The interesting thing about this: The club had about 75 cars. one straight 8 Buick, one V8 Cadalic, and one 6 cl Chevy. and over 8 years of racing there were very few engine failures
