Old 12-04-2021, 08:59 PM   #1
MotownMachine
MotownMachine's Avatar
Default Rotor Height
Hi all. I had a question about the distributor rotor and could not find information anywhere else. It looks like my rotor is sitting too low and will not make contact with the spark plugs. I am getting spark at the points and the rotor spins when turning over. Is there any way to adjust this, or does the rotor contact normally sit lower than the spark plug points?
Thanks
MotownMachine is offline   Reply With Quote
Old 12-04-2021, 09:15 PM   #2
wwirz
Default Re: Rotor Height
No. The rotor should not be sitting lower than the points. Hard for me to think about how this could happen. Did you remove the cam? In this forum there are pictures on correct location of the rotor when the Model A is properly timed. Do you have the Les Andrews "RED BOOK"? There are many illustrations in there as well as much infomration on how to service your A.. Send me an EMAIL and I can send more info to you. Also be sure to join a local Model A club.
wwirz is offline   Reply With Quote
Old 12-04-2021, 10:51 PM   #3
MotownMachine
Cam has not been removed since I have owned it. Thanks for the advice. Found out last week that there is a local club in the next county over.
Old 12-05-2021, 12:44 AM   #4
1crosscut
1crosscut's Avatar
You do not want the rotor to actually touch the contacts on the inside of the distributor body. There needs to be a gap. This thread should help.
https://www.fordbarn.com/forum/showt...sure+rotor+gap
Dave / Lincoln Nebraska
1crosscut is offline   Reply With Quote
Old 12-05-2021, 12:53 AM   #5
Brentwood Bob
Missing the lock washer under the large flathead screw that holds the cam in place?
Brentwood Bob is offline   Reply With Quote
Old 12-05-2021, 04:17 AM   #6
john charlton
john charlton's Avatar
I have found this problem where the rotor contact is too low .I cure this by using the phenolic washer from the distributor input (from my dist spares box)I put the washer in the rotor which raises the rotor for correct alignment . This does not seem to make the rotor wobbly and works just fine .Do not try to bend the rotor contact even if you can the rotor contact could be too close . If you dont have that washer a flat shirt button will do .
John in Bath Somerset County England weekend with eldest daughter and granddaughter partly cloudy with sunny spells .
Old 12-05-2021, 08:45 AM   #7
Bob Bidonde
Bob Bidonde's Avatar
These slides may help you:
Bob Bidonde
Old 12-05-2021, 09:56 AM   #8
Bruce Newbery
I had a similar problem but my rotor was to high. I had a new distributor body that was to low and caused a premature rotor failure . I suggest you get a origin Ford body and measure and compare the two. Some of these replacement parts are not up to Ford spec.
Bruce Newbery is offline   Reply With Quote
