02-11-2020, 11:55 AM | #1 |
28/29 82A & 30/31 82B Closed Cab Pick Up
Education needed: can someone list the differences between the 82A and the 82B pick ups?
Thanks in advance. |
02-11-2020, 12:24 PM | #2 |
Re: 28/29 82A & 30/31 82B Closed Cab Pick Up
The 28-29 trucks had a square cab, 30-31 trucks had a rounded cab. and bigger rear window. Late '31 trucks had a wider, longer bed, fuel shut-off on the front side of the firewall and other minor changes.
02-11-2020, 12:46 PM | #3 |
There are a lot of differences between the two.
To build on what was said before. 1928-mid 1930 is a "square cab". In mid 1930 the body style was changed to a more rounded cab. In mid 1931 the bed was changed to a "wide-bed" style. Also in mid 1931 a Deluxe pickup was introduced that had a bed that "flowed" into the cab. In August/September of 1931 they became a "steel top" which was a stamped steel panel that replaced the fabric covered roof of the earlier ones. For more reference check out this illustrated body reference. http://www.gwcmodela.com/bodyphotos.asp#stop1 -Tim
No one wants advice - only corroboration. -John Steinbeck |
02-11-2020, 12:51 PM | #4 |
The list of what is the same would be a lot shorter.
02-12-2020, 12:14 AM | #5 |
02-13-2020, 10:42 PM | #6 |
Bill Worden 1929 Roadster 1929 Briggs Town Sedan 1930 Closed Cab pickup Smith Motor Compressor 1951 Ford F1 High Desert Model A's |
