05-13-2020, 09:08 PM | #1 |
Stud Removal or ?
I have a new pop out switch and cable with the thick ignition cable clamp.
Issue is the stud on number 8 cylinder is the shorter version the the clamp will not work with that size stud. Question? Does anyone think I should remove the one stud and replace it with the long version (4 1/16") stud - or install the thin ignition cable clamp? I don't want to create bigger problems by removing the stud.... not that i necessarily would but I like to ask the 'experts' Thanks! |
05-13-2020, 09:32 PM | #2 |
Re: Stud Removal or ?
Check your "Private Messages" in the upper right corner of this web page.
Marshall |
05-14-2020, 02:08 AM | #3 |
I removed the clamp, it makes working on the dizzy easier if you need to remove the dizzy!
05-14-2020, 05:20 AM | #4 |
Don't touch that stud. It's happy there and so are you.
05-14-2020, 07:25 AM | #5 |
Cut a slit in the original clamp. Bend it open. Insert your new larger cable. Close the clamp up again just enough to hold the new larger cable.
05-14-2020, 07:32 AM | #6 | |
Happy A motoring ! Larry |
05-14-2020, 07:39 AM | #7 |
Thanks for the advise and help!
