Old 06-20-2017, 07:55 PM   #1
Bill in NJ
Default Gano auto coolant filter
What size it needed for a model a? I assume the clear ones are better ? What is the approx cost ? Thanks in advance.
Bill in NJ is offline   Reply With Quote
Old 06-20-2017, 08:18 PM   #2
RawhideKid
Default Re: Gano auto coolant filter
http://www.ganofilters.com/
Before Walmart you had to buy a ticket to the fair to see a bearded lady!
RawhideKid is offline   Reply With Quote
Old 06-20-2017, 09:53 PM   #3
Brian SATX
Brian SATX's Avatar
I use the clear one. You can tell when it needs to be cleaned that way. I really like it.
Brian SATX
Brian SATX is offline   Reply With Quote
Old 06-20-2017, 10:52 PM   #4
Vern
Vern's Avatar
I seem to recall that the filter cost about &55.00. When they say don't use any caustic coolant as it will deteriorate the clear plastic, believe it.
Vern is offline   Reply With Quote
Old 06-20-2017, 11:35 PM   #5
RawhideKid
Well, lets see.....the bottom hose is 1¾, and the top hose is 2". Now, I ordered the one for the 2" since that is where I placed mine, and would recommend that is where you put yours to keep the garbage from entering the radiator. It also makes it easy to clean up there.
Old 06-21-2017, 01:17 AM   #6
Clockguy2
About 8" of the toe of a nylon stocking slipped over the radiator inlet before fastening the hose on does the same thing for about a dollar. Just change it out yearly.
Clockguy2 is offline   Reply With Quote
Old 06-21-2017, 03:45 AM   #7
Dollar Bill
Dollar Bill's Avatar
I installed one of the clear Gano filters several years ago. The ability to see coolant is an added bonus.
Tom W posted a Caterpillar strainer that will also serve to keep your radiator clean.
I Love Anything That Turns Money Into Noise
Dollar Bill is offline   Reply With Quote
Old 06-21-2017, 10:02 AM   #8
glenn in camino
glenn in camino's Avatar
Use the size if the upper hose.
Old 05-28-2018, 07:40 PM   #9
frmhrt
in a '49 flathead V8 with a coolant line from each side of the block to the radiator is it necessary to install a Gano filter in each of the two lines?
thx
af
frmhrt is offline   Reply With Quote
Old 05-28-2018, 07:58 PM   #10
Tom Endy
Tom Endy's Avatar
I just received two from Gano. I ordered the clear, size "large" 1 3/4" to 1 7/8" I.D. They fit inside the upper hose perfectly. They are $42 each. They look to be well made.
Tom Endy
Old 05-29-2018, 03:38 AM   #11
Dollar Bill
Originally Posted by frmhrt View Post
in a '49 flathead V8 with a coolant line from each side of the block to the radiator is it necessary to install a Gano filter in each of the two lines? thx af
You will have only partial coolant filtering with a single screen.
