Old 04-12-2021, 05:15 PM   #1
STAN WHITE
Default 34 ford radiator
I HAD A SPECIAL RADIATOR BUILT MANY YEARS AGO. IT IS WHAT i WOULD CALL A SHOW RADIATOR. ALL BRASS WITH A PRESSURE CAP. PUTTING MY COUPE BACK TOGETHER AFTER MANY YEARS. SO I MOCKED IT UP WITH FRONT FENDERS & GRILL. i HAVE A PROBLEM WITH THE RADIATOR DIMENSIONS. MOUNTS FOR UPPER GRILL TO THE TANK ARE OFF BY THREE QUARTERS OF AN INCH.NEEDS TO GO BACK THAT MUCH. BUMMER !!. Looks like I will go with a stock radiator. My question is why do I need a pressurized radiator?. Ran it many years ago stock radiator & fan set up with 180 degree thermostats 50/50 mix antifreez/water no problems. I AM RUNNING A MODIFIED 59 AB ENGINE, It never overheated on me!. It seems to me that most everyone is running a pressurized radiator these days. I WOULD APPRECIATE SOME HELP ON THIS. thanks! stan
STAN WHITE is offline   Reply With Quote
Old 04-12-2021, 05:29 PM   #2
cas3
Default Re: 34 ford radiator
stock brassworks radiator in my 34, no pressure cap, 59a block cleaned, and thermostats runs cool as a cucumber.
Old 04-12-2021, 05:51 PM   #3
STAN WHITE
Thanks Cars3. I guess I will have to go with one of those if they are still available. Did every thing line up for grill & inner fender panels? Front Hood latch mounts & radiator rods etc?. Thanks Stan
Old 04-12-2021, 06:14 PM   #4
Lawrie
Lawrie's Avatar
33 with a 99a engine, stock rad and cooling ,towed the caravan in the hills in 2nd gear in 44C, and on the flat in 47C ,no over heat
Lawrie
Old 04-12-2021, 08:37 PM   #5
JSeery
JSeery's Avatar
Stock (and even modified) flatheads with 33-34 radiators do not use a pressurized cap. Because of the size and shape of the upper tank it is difficult to use one without ballooning it.
Old 04-12-2021, 10:01 PM   #6
51504bat
51504bat's Avatar
I'd give Lee a call at Brassworks in Paso Robles, CA He might be able to modify the one you have to work or he can build you a new one. Might be worth a trip over the Sierra's to see. A repair might be expensive but most likely less than a new radiator. Either way it will be a couple of months or longer wait.
https://thebrassworks.net/
(805) 239-2501
Old 04-12-2021, 10:20 PM   #7
cas3
Stan, my car is an old school jalopy, so no fenders. Hood and grill lined up fine. Brassworks stuff is usually about the best you can buy from what i know, but they are not cheap
