Old 11-11-2017, 12:57 PM   #1
Charlville
Charlville's Avatar
Default Vintage Fords on VSCC Welsh Trial 2017
I thought I'd share this video from SimonLewsBooks on YouTube.
Various Model A's tackling the trial course!
https://www.youtube.com/watch?v=JSDQ4BcIiWc&t=44s
Kevin Flood
West Berkshire UK
Member MAFCGB, VHRA, SAH, Brooklands Trust
Sporadic progress on My 1929 Sport Coupe can be found here along with my blog
http://automotiveamerican.com/
Charlville is offline   Reply With Quote
Old 11-11-2017, 01:43 PM   #2
Chuck Dempsey
Chuck Dempsey's Avatar
Default Re: Vintage Fords on VSCC Welsh Trial 2017
Great! Nice to see the younger folk and women behind the wheels.....
Chuck Dempsey is offline   Reply With Quote
Old 11-11-2017, 05:19 PM   #3
Mad Mac
By the sound of the motors they are all the UK under-powered version?
Mad Mac is offline   Reply With Quote
Old 11-11-2017, 05:49 PM   #4
updraught
updraught's Avatar
Are they still trying to save on tax?
Must be because of Brexit.
updraught is offline   Reply With Quote
Old 11-12-2017, 04:59 AM   #5
johnbuckley
johnbuckley's Avatar
....by the sound of the motors they are all the UK under-powered version?
No, I can assure you all these are the standard 3.875 inch bore (3285cc) engine. Very few of the small bore engines are still around over here... (we reckon only 40-50) see the club website www.mafcgb.org.uk for the archived data base of known Model As in the UK.
johnbuckley is offline   Reply With Quote
Old 11-12-2017, 08:03 AM   #6
2manycars
2manycars's Avatar
I noticed several cars were left hand drive. I also noticed the red phaeton appeared to have dual SU carbs, which I have often thought of fitting. Maybe a pair from a A-H 3000, or from a Rover 3.5.
Bill
www.brauchauto.com
2manycars is offline   Reply With Quote
Old 11-13-2017, 05:00 AM   #7
Charlville
Charlville's Avatar
As John rightly says the majority of A's over here have the larger engine as they are imports, including mine. As for Brexit we've got about as much idea as our government which = 0
Kevin Flood
West Berkshire UK
Old 11-13-2017, 06:52 AM   #8
Synchro909
Synchro909's Avatar
FWIW, I think if you do that, you will be over doing the carburation. Those engines are close to the same size as the Model A but rev MUCH higher. As a guide, when I was looking for a down draught carburetor for my A, I multiplied the engine capacity by the max revs for the two and compared that.
I chose a Stromberg from a 1950's Holden. The Holden motor was about 2.3 litres and revved to about 5K 2.3x 5000= 11,500. The Model A motor is 3.3 litres and revs to say, 3,000 rpm. 3.3x 3000=9,900. The Holden carby was PLENTY big enough but not so over sized that the lower end of the rev range was compromised. Many people use a carby that is too large and spoil the "driveability" of the car
It's a quick and simple way to determine whether a carby is suited to a different motor.
I'm part of the only ever generation with an analogue childhood and a digital adulthood.
Old 11-13-2017, 07:27 AM   #9
Charlville
Charlville's Avatar
You've peaked my interest So would that Holden be a six similar to the Chevy Stovebolt or even a Vauxhall over here?
Kevin Flood
West Berkshire UK
Old 11-13-2017, 11:08 AM   #10
2manycars
2manycars's Avatar
Originally Posted by Synchro909 View Post
FWIW, I think if you do that, you will be over doing the carbonation. Those engines are close to the same size as the Model A but rev MUCH higher. As a guide, when I was looking for a down draught carburetor for my A, I multiplied the engine capacity by the max revs for the two and compared that.
Thanks for that info. I have noticed that problem when people have fitted a weber progressive 2 barrel carb to their MGB. They fall flat until RPM is at mid range.
Perhaps a pair of MGB SU carbs would be enough. 1.8 x 5000 comes to 9000, which should work fine.
Bill
www.brauchauto.com
Old 11-13-2017, 03:43 PM   #11
Synchro909
Synchro909's Avatar
Never heard of a Chev Stovebolt but I think the Vauxhalls were similar. They were a 2.3 litre six cylinder OHV motor used by Holden from 1948 till about 1963. Being a GM product, I wouldn't be surprised if the Stovebolt was very similar.
Old 11-13-2017, 03:55 PM   #12
Synchro909
Synchro909's Avatar
As soon as I posted, I thought I should have mentioned that a progressive carby shouldn't be so bad but still to be watched. An engine being "flat" till higher revs are attained can be due to the cam grind also. One often sees an inexperienced "go fast" car owner over do it with both carb and cam, an easy mistake for the over zealous but to be avoided.
Perhaps a member who has competed in a Model A could confirm that, maybe Jim Brierly?
Old 11-13-2017, 10:15 PM   #13
updraught
updraught's Avatar
" ... I have noticed that problem when people have fitted a weber progressive 2 barrel carb to their MGB. They fall flat until RPM is at mid range."
Maybe the intake manifold is too big? I thought the idea of the side draught was to remove the bends in the intake manifold and make it more responsive.
My understanding, from nowhere in particular, was that the Holden 6 was just a variation of the Chevy 6 (stovebolt?) from the late 20's.
However, the font of all knowledge Wikipedia, says:
" The engine was based on a Buick pre-World War II design, and saw only minor changes throughout its 15-year life."
https://en.wikipedia.org/wiki/Holden_straight-six_motor
An advert from 1964 with the new redesigned "red" engine:
https://www.uniquecarsandparts.com.a...Red_Motor.webm
Old 11-13-2017, 10:37 PM   #14
1930artdeco
1930artdeco's Avatar
I thought it was a fun video and would have no idea on how to drive my car in the mud. But, I assume all of the bouncing was to gain traction-or just for fun.
Mike
1930 TownSedan (Briggs)
1957 Country Sedan
Old 11-13-2017, 11:51 PM   #15
al's28/33
al's28/33's Avatar
Those were the types of roads the "A" was built for..... AMEN!
1928 "A" Phaeton (mid year with many early features)
1933 "V8" Closed-Cab Pickup Truck
(originally a Model B, 4 Cylinder dating to May, 1933)
Old 11-14-2017, 04:24 AM   #16
johnbuckley
Mike
If the bouncing is correctly synchronised it helps traction a lot, also the tires are generally dropped to about 12 psi ;glue on the rims helps the tire from slipping round. All good ( but not clean!) fun
Old 11-14-2017, 07:18 AM   #17
Charlville
Charlville's Avatar
Some more trials background:
http://www.vscc.co.uk/page/trials
Here's a Model A Special Trials Car
http://teamtwirp.co.uk/the-cars1/for...al-trials-car/
Kevin Flood
West Berkshire UK
Old 11-14-2017, 07:19 AM   #18
nosbod
nosbod's Avatar
John is quite correct about bouncing to aid traction but bouncing also slows the car down so a delicate balance is needed to achieve forward motion and speed. After many years of trialing I realise its a black art perfected by few but enjoyed by many, certainly the greatest fun available on four wheels and includes all the family if they willing to get down dirty on a wet weekend.
Picture attached of last weekend's fun in The Lake District.
nosbod is offline   Reply With Quote
Old 11-14-2017, 07:53 AM   #19
Charlville
Charlville's Avatar
Hi Nosbod
How do you set the cars up spring/shocker wise or is it all standard stuff?
Cheers
Kevin
Kevin Flood
West Berkshire UK
Old 11-14-2017, 09:02 AM   #20
nosbod
nosbod's Avatar
Hi Kevin,
There are basically two classes, standard and modified. I run in the standard long wheelbase class which allows no changes from original including tyre and wheel sizes, engine suspension etc. This class is virtually a Model A benefit which is a great challenge as only 27 points covered the whole class last weekend on The Lakes. the green Phaeton next to mine is modified so can leave off the bumpers, use bigger tyres, tune the engine and add ballast etc. This for me is not the spirit of the event but its whatever turns you on. Long may it continue!
John
Thread Tools
Display Modes
