Old 01-24-2017, 03:22 AM   #1
1oldtimer
1oldtimer's Avatar
Default 1947 pedal shaft and bushings
Has anyone replaced the pedal shaft, is it even replaceable it looks like piece to me. There's someone on Ebay selling the shaft, I have 2 pedal assy and both shafts are worn. My 2 choices are to either replace the shaft or turn down the shaft and make new bushings out of oilite. I'm dumb and saw an NOS one but didn't get it.
Also what's the difference between 1940 and 1947 pedals?.
1oldtimer is offline   Reply With Quote
Old 01-24-2017, 08:00 AM   #2
Terry,OH
Terry,OH's Avatar
Default Re: 1947 pedal shaft and bushings
The same brake bracket and shaft were used from 40-48. The shaft is pressed into the bracket and is is not all that hard of a job to replace it. The washers and clips at the end of the shaft that retain the pedals are hard to find. Most of the aftermarket parts suppliers sell the shaft.
Old 01-24-2017, 08:10 AM   #3
skidmarks
skidmarks's Avatar
Its not that tight but you need a press and have to support the bracket so you dont break it
skidmarks is offline   Reply With Quote
Old 01-26-2017, 12:34 AM   #4
1oldtimer
1oldtimer's Avatar
That's good to know. Is there a difference on the pedal arms between the '40 and '47?. I have a '40 that I was going to rebuild and put in my '47 or should I just rebuild the '47 pedals.
Old 01-26-2017, 07:51 AM   #5
skidmarks
skidmarks's Avatar
Arms are different. Atleast the clutch is. It has more of a curve then a 40. The frame bracket is the same. Check the part number on the side of the pedal arm
Old 01-26-2017, 10:50 AM   #6
Old Henry
Old Henry's Avatar
Brake pedal shaft and bushings are available new here: http://cgfordparts.com/ufolder/cgcat...&searchnumber=
New clutch pedal shaft and bushings here: http://cgfordparts.com/ufolder/cgcat...&searchnumber=
