Old 07-21-2015, 03:00 PM   #1
dmsfrr
dmsfrr's Avatar
Default Have I gone around the bend? '55 F-100
I spotted this truck for sale on the side of the road the other day (while wearing 'Sunday' clothes).
It's driveable, the exhaust is clean when it starts & runs, and the body doesn't look too bad. The front fenders are kind of rough w/ bondo in the front, but no obvious rust-thru except under the gas tank neck and patches at the front edge of the rear fenders.
Was told it has the original 272 & 3spd, but the carb looks newer, I haven't checked the block number yet. The wood in the bed is all missing but the bottom sides of the box aren't rusted. The interior has fresh paint, with what looks like new gauges and a recent seatcover.
It comes with door panels, a popper kit for the (shaved) door handles, a few extra parts and another frame that was being prepped for the truck (I haven't seen it yet) that has a disc brake Mustang II front suspension and a 9 inch rear end.
I'm not a truck guy and don't have a clue what they're worth. What trouble spots should I look for
Does anyone want to hazard a guess on what's a good offer to make for it?
dmsfrr is offline   Reply With Quote
Old 07-22-2015, 04:06 AM   #2
RCM
RCM's Avatar
Default Re: Have I gone around the bend? '55 F-100
Did he/you get it running? To me that would be the main issue, body work wouldnt. Body work can be done over time, but if it doesnt go, then one can get frustrated and with a light pocket.
I like her tough...she seems sad and in need of care
RCM is offline   Reply With Quote
Old 07-22-2015, 11:16 AM   #3
frank long island
frank long island's Avatar
As stated above unless you can do the work yourself it can get costly. The body seems fairly good the rust you see is common on those years . Also ck the hinge pillars and rockers and bodt mounts. All repair parts are available . For mee it wouldnt be bad as i'm a bodyman by trade anything can be repaired as for value maybe someone could set that but as the saying goes its only worth what someone will pay
frank long island is offline   Reply With Quote
Old 07-22-2015, 03:17 PM   #4
scicala
scicala's Avatar
Well, if it is the original 272, the intake is from '57 or later and the Autolite 2100 carb is from the 60's. Do the heads have core plugs on the front and rear faces ? If not, the heads are '56 or later.
Sal
Old 07-22-2015, 04:38 PM   #5
dmsfrr
dmsfrr's Avatar
It had been sitting for a week when I saw it, he splashed some gas in the carb and it started right up and stayed running. It idles fine, no smoke when started or revved and the rocker arms didn't seem noisy.
I was on my way somewhere else and couldn't spend much time looking. I need to go back and look again while wearing clothes I can crawl underneath it in.
Old 07-22-2015, 09:57 PM   #6
Daves55Sedan
Daves55Sedan's Avatar
Its a '53, 54 or '55 pickup, but it has a 292 intake from a '57 or later year engine, converted to 12 volts, but don't see the ballast resistor for the coil. They took out the original steering column and replaced it with a '56 truck column. Spark plug wires should be run under the exh manifolds not above. the acorn nuts are missing off the T-bird valve covers. I don't think any pickup trucks had those valve covers. Hood opens wrong way unless you don't care about keeping it original.
Daves55Sedan is offline   Reply With Quote
Old 07-23-2015, 03:29 AM   #7
RCM
RCM's Avatar
I believe this is what dmsfrr is waiting for:
Old 07-23-2015, 07:33 AM   #8
Ford blue blood
Ford blue blood's Avatar
Looks like it once had $500 on the windshield? Given all the "normal" rust areas in the bed sides, running boards, fenders and cab corners look OK and the glass all looks good it looks like a good solid base to start with. Hit him/her with 1500.......
Bill, certified Ford nut.
2016 F-150
2016 Focus
08 Shelby GT500
57 Ford Ranchero
36 Chevy, 351C/FMX, 8", Mustang II
Ford blue blood is offline   Reply With Quote
Old 07-23-2015, 08:27 AM   #9
RCM
RCM's Avatar
Yup 500 or 600 was once written there. One could carry that argument up the sleeve and ask about that pricing. I gotta soft spot for that puppy already!
Old 07-23-2015, 10:26 AM   #10
dmsfrr
dmsfrr's Avatar
The 500 is just the last 3 digits of the price on the windshield, he has a 5 in front of that, for a 5500 asking price. I thought that was a little high but don't know what they go for, and the extra updated frame for it is included in the price too.
Not that I have a place to put it, and I've got an unfinished car already.
If I could get it for 'a real steal of a price' I might consider it.
Old 07-23-2015, 10:53 AM   #11
Y-Blockhead
Y-Blockhead's Avatar
The exhaust manifold is not stock on the right side, trucks had single exhaust with the crossover pipe. Can't see left side but exhaust pipe is looped forward so probably has original on that side.
Old 07-23-2015, 10:57 AM   #12
Y-Blockhead
Originally Posted by RCM View Post
Did he/you get it running? To me that would be the main issue...
It's driveable, the exhaust is clean when it starts & runs...
Old 07-23-2015, 11:12 AM   #13
y'sguy
y'sguy's Avatar
Well, IMHO I would never give 5500 for it. But I'm not in the market for it either. All that matters really is if you two guys can get together on a price. I'm thinking that earlier version of those trucks doesn't bring the money as the 56's but that only really matters to resellers.
Everyone seems to have their favorites. And hey it runs and drives!
y'sguy is offline   Reply With Quote
Old 07-23-2015, 12:28 PM   #14
GreenMonster48
GreenMonster48's Avatar
I wouldn't go more than $2500-3k. You're out in dry country. I'd imagine old trucks are a dime a dozen out there.
GreenMonster48 is offline   Reply With Quote
Old 07-23-2015, 01:00 PM   #15
joe plumber
I wouldn't give that much for it,still too high
joe plumber is offline   Reply With Quote
