Old 06-16-2014, 07:51 PM   #1
Will N
Will N's Avatar
Default early carb, GAV needle seat
Is there a gasket used on the screw in GAV needle seat used on the early carbs?
Thanks!
Will N is offline   Reply With Quote
Old 06-16-2014, 08:45 PM   #2
160B
160B's Avatar
Default Re: early carb, GAV needle seat
Thanks!
Yes
1931 160B & 1931 68B
If you don't have time to do it right the 1st time, how do you have time to do it the 2nd time?
160B is offline   Reply With Quote
Old 06-16-2014, 10:35 PM   #3
Tom Endy
Tom Endy's Avatar
Yes, the early brass GAV needle seat uses a small gasket the same as is used under the main, comp, and cap jets. The idle jet is a small pipe thread and does not use a gasket. Be sure not to mix the GAV seat with the comp jet. They look very much alike. Also remember to install the GAV seat before you install the GAV assembly.
Tom Endy
Tom Endy is offline   Reply With Quote
Old 06-16-2014, 11:22 PM   #4
160B
160B's Avatar
The thread form on all the jets is metric. The thread form is metric M5-.75.
The reason the idle jet does not need a gasket is because it has a tapered shoulder that seats against the cast iron upper body.
Toms point on not getting the GAV seat and the comp jet interchanged is important, I have seen too many rebuilds with a GAV seat installed where the comp jet belongs.
Old 06-17-2014, 07:13 AM   #5
Will N
Will N's Avatar
Thanks guys. I asked because the "red book" specifically mentions the gaskets under those three jets, but does not mention the gasket under the GAV needle seat.
