Old 01-08-2021, 10:06 AM   #21
nkaminar
nkaminar's Avatar
Default Re: Crazy temp gauge idea
I would say to Blown Gasket, if it makes you happy, go for it. Personally I like the Motometer, although the bulb and capillary tube gauge came on my car and no motometer.
Old 01-08-2021, 10:15 AM   #22
katy
katy's Avatar
Originally Posted by alexiskai View Post
If you're committed to using it, why not put a 6V-12V step-up converter in the circuit instead?
Ditto
Old 01-08-2021, 04:26 PM   #23
Synchro909
Synchro909's Avatar
It doesn't take much of an overheat episode to crack a Model A block (usually at #2 or #3 exhaust port to the cylinder). The way we drive these cars is nothing like the way they were expected to be driven when they were made which makes overheating a much more likely occurrence. One of the first things I do is install a temp gauge.
Old 01-08-2021, 04:52 PM   #24
AL in NY
AL in NY's Avatar
OMI: Buy a good mechanical temperature gauge for $50.00 and do away with all the excess batteries and wiring.
AL in NY
AL in NY is offline   Reply With Quote
Old 01-08-2021, 05:54 PM   #25
Blown Gasket
Blown Gasket's Avatar
My crazy idea has come to an end and I will buy new mechanical one. What convinced me was when I looked at my new gauge bought over a year ago for my backhoe it reads in Celsius with 120 max. If I had that in the car I would forget and freak out.
Blown Gasket is offline   Reply With Quote
Old 01-08-2021, 05:55 PM   #26
Y-Blockhead
Y-Blockhead's Avatar
I was thinking the same, keep it simple...
Old 01-08-2021, 11:04 PM   #27
daren007
Have you ever heard the saying, “You won the battle but you lost the war”.
daren007 is offline   Reply With Quote
Old 01-08-2021, 11:44 PM   #28
Synchro909
Synchro909's Avatar
With by far the majority of the world using Celsius, why do American vendors insist on selling the antiquated Fahrenheit stuff without even a second scale? When I look at my US made tamp gauge and it is showing 180 degrees, I freak!
Old 01-09-2021, 12:47 AM   #29
SteveB31
SteveB31's Avatar
Or just buy a mechanical temp gauge .
SteveB31 is offline   Reply With Quote
Old 01-09-2021, 02:13 AM   #30
Pdstark
Pdstark's Avatar
It would be a blast to hang out in your garage.... Do it and share photos of the completed project.
Pdstark is offline   Reply With Quote
Old 01-09-2021, 08:52 AM   #31
McMimmcs
McMimmcs's Avatar
Smart man !
Old 01-09-2021, 08:56 AM   #32
Chris in WNC
Chris in WNC's Avatar
may be antiquated but it's what we understand and are familiar with.
when the doctor's scale reads kilos I remind them what country we are in....
we've already lost the battle with metric bolts and litres of soda.
I'm sure my grandchildren are more comfortable with it than I.....
our next Model A is out there in the unknown......
Chris in WNC is offline   Reply With Quote
Old 01-09-2021, 01:07 PM   #33
Brendan
Brendan's Avatar
This may sound like a crazy idea but when I worked I was paid to come up with crazy ideas. In my new "A" which is going to ship Monday I would like to have a temp gauge. I bought one about a year ago for my backhoe but never needed it. It's 12V and will not work on 6 so I thought about it and came up with this. I would drill the water outlet, not buy a new one and silver braze a brass fitting in it for the sender. Then buy a 12 volt sealed rechargeable battery, $20 find a place to store it, it's small. Then put a seat sensor switch in the drivers side seat so it was only on when sitting and driving. Now hide the wires as best as I can. Has it been done?
why not buy a water outlet with a fitting in it and a mechanical gauge
If it would have been a snake it would have bit ya!
i can't spell my way out of a paper bag!
Brendan is offline   Reply With Quote
Old 01-09-2021, 02:36 PM   #34
woofa.express
woofa.express's Avatar
Originally Posted by Floats View Post
Gasket
These cars have been going fine for nearly a 100 years, without a temp gauge. Why would you want a temp gauge and where would you place the gauge?
I have a new radiator in my tourer and a new pressurised radiator in my ute. Both '28. Today and next 4 days are forecast to be 38c (100F) or excess. Keeping them cool is still a problem even with a 5 blade plastic fan and shroud. I have installed a temp gauge in the ute and am converting to 12v before I can connect. I am about to install one in the tourer which is now 12v. In addition I carry 10 litres of water in each vehicle.
However because I need a temp gauge I am not saying that you or others do. Many of you don't live in a hot climate.
My gauge is placed on the steering column. The cross bar between the mudguards would be another place unless you are short sighted. Appearance is important but practicality more so.
These are my views and I am not intending to be contrary or argumentative or to appear authoritative.
I know many things,
But I don't know everything,
Sometimes I forget things.
And there are times when I have a long memory.
woofa.express is offline   Reply With Quote
Old 01-09-2021, 03:53 PM   #35
Blown Gasket
It will take me about 20 minutes to drill a hole and braze in a fitting.
