Old 12-30-2020, 01:08 PM   #1
AL in NY
AL in NY's Avatar
Default 283 Model A Pistons
Is anyone currently making reasonable priced 283 pistons that fix standard length Model A rods?
AL in NY
AL in NY is offline   Reply With Quote
Old 12-30-2020, 01:42 PM   #2
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
Default Re: 283 Model A Pistons
Wasn't Rich Fallucca making them?? I don't use them, so I have no idea whether he still offers them, but at one time I thought he was.
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 12-30-2020, 05:10 PM   #3
AL in NY
AL in NY's Avatar
Terry, I believe AER only offers different length rods that will work with the OEM 283 piston. That won't work for me as I am considering buying the new Terry Burtz Model A engine which comes with special offset cap rods which that are the same length as the the Model A rods. I have a call into John Cosper at Pete's Auto-machine to see if he still offers 283 pistons for standard length Model A rods.
AL in NY
Old 12-30-2020, 05:11 PM   #4
Lawrie
Lawrie's Avatar
Try EGGE machine, they make a nice thin ring piston for the A.
And you can get total seal rings for them.
Lawrie
Old 12-30-2020, 09:59 PM   #5
Terry Burtz, Calif
In the engineering evaluation engine, we used the EGGE 1104-4 piston set with the Hastings 665 ring set. Both were bought from EGGE.
The width of the 2 compression rings are 5/64 (.078 inch, 1.5 mm) and the oil ring is 3/16 inch wide.
Out of the box, the pistons fit with .004 inch clearance and the ring gaps were within tolerance.
Terry Burtz, Calif is offline   Reply With Quote
