07-17-2017, 08:18 PM | #1 |
Banjo rebuilders
Wasn't there someone in Southern California that had a service to rebuild banjo rearend?.
07-17-2017, 08:35 PM | #2 |
Re: Banjo rebuilders
You might try Richard Lacy here.
http://www.earlyv8garage.qpg.com/ |
07-17-2017, 08:49 PM | #3 |
What year? If it is early '32 you might try Tom Endy since he is the Model A rear end expert and they are basically a Model A rear end.
Charlie Stephens |
07-17-2017, 09:06 PM | #4 |
It's a mix of parts. But it's a '47 truck center with '36 bells. I need pick someone's brain or have setup the pinion and side bearing preload.
07-17-2017, 09:36 PM | #5 |
As Charlie said, Tom Endy is the guru on model a rear ends. See if this helps you at all.
http://www.santaanitaas.org/wp-conte...vised-2014.pdf |
07-17-2017, 10:59 PM | #6 |
07-18-2017, 05:16 AM | #7 |
That's the best artical/write up I've seen on rebuilding rear ends for our cars.
I used it on my rebuild of a '46-'48 rear axle. |
