Old 07-14-2021, 01:06 PM   #1
Werner
Werner's Avatar
Default Oil pump pressure/delivery
Guten Abend.
Is there a data sheet for the delivery rate of the oil pump and the oil pump pressure against a closed pressure line?
Or has someone made their own approximate measurements?
I thank you in advance for any advice!
Beste Gruesse aus Deutschland,
Werner
Ford Model A, Roadster, 1928
Citroen 11 CV, 1947
Hercules W 2000, 1976; (with NSU-Wankel Rotary Engine), Canadian version
Werner is offline   Reply With Quote
Old 07-15-2021, 08:30 AM   #2
Bob Bidonde
Bob Bidonde's Avatar
Default Re: Oil pump pressure/delivery
This is from MAC's webpage https://www.macsautoparts.com/modela_specs2#oil
Oil Pump Specifications
Type: Pump, splash, gravity feed
Crankshaft Bearings: Gravity feed
Connecting Rods: Splash
Camshaft Bearings: Gravity feed
Oil Pump Type: Gear
Oil Pump Capacity: 9 pints, minimum at 1300 rpm
Oil Pump Pressure: 80-100 pounds
Oil Pump Shaft: 1/2" diameter (in 5/8" bore), except 1928 with 9/16" bore & undercut shaft (Model B used 5/8" bore with undercut shaft)
Oil Pump Gear Teeth to Housing Clearance: .001" to .002"
Housing Cover to Face of Gears Clearance: .001" to .002"
Drive Gear to Camshaft Gear Clearance: .003" to .005"
Bob Bidonde
Old 07-15-2021, 10:59 AM   #3
katy
katy's Avatar
Is that 9 pints per second? minute? Or?
