Old 09-25-2015, 11:02 AM   #1
john in illinois
john in illinois's Avatar
Default Column drop twist off bolt removal
The break away clamp bolt on this column drop was broken off when I got it.
Does anyone have any tips to remove it?
I am thinking weld on washer/nut or somehow drilling it.
John
john in illinois is offline   Reply With Quote
Old 09-25-2015, 11:08 AM   #2
deuce_roadster
deuce_roadster's Avatar
Default Re: Column drop twist off bolt removal
Every one I have removed with an easy-out. They aren't real tight and unscrew. If it was all rusty you may need some penetrating oil and or heat. Yours may need that. The threads are fine so that makes it a little tougher. You may want to soak the other end with some kind of penetrant.
Old 09-25-2015, 11:10 AM   #3
Andy
I like to save them. I drill a series of 1/16" holes across the face and then angle the drill to make a screwdriver slot. A little heat maybe and they come right out and are reusable.
Andy is offline   Reply With Quote
Old 09-25-2015, 11:41 AM   #4
32phil
easy out ...a little heat if necessary...once the bolt is out you can cut a slot in it and re use it in the same drop it lived in for 80 some years or so......a little Karma thing I do.....
Early Ford Lock & Key Service
http://www.fordbarn.com/forum/showthread.php?t=46583
32phil is offline   Reply With Quote
Old 09-25-2015, 11:46 AM   #5
john in illinois
Thanks for the replies. I like the idea of saving the bolt. Allen replacement bolts seem kind of out of place.
John
Old 09-25-2015, 12:43 PM   #6
mike in tucson
Here is a pic of a drop that I am getting ready to restore..but will use the slotted solution that someone made a long time ago. John is correct that a socket hex head bolt looks really bad in this location.
mike in tucson is offline   Reply With Quote
Old 09-25-2015, 12:48 PM   #7
Charlie Stephens
John
You might try Roy Nacewicz Parts, (313) 383-3673, fordbolts.com
Charlie Stephens
Old 09-25-2015, 01:01 PM   #8
Flowmeister
Flowmeister's Avatar
The bolts from Roy Nacewicz
Flowmeister is offline   Reply With Quote
Old 09-25-2015, 01:53 PM   #9
19Fordy
19Fordy's Avatar
Before installing the new "RN" bolt why not just twist off the head and saw a slot for a screwdriver. Then install. Will make it easier for the next guy who has to remove it 100 years from now.
Old 09-25-2015, 04:34 PM   #10
john in illinois
I got it out with a 1/8" easy out ,Kroil and heat.I can fill the hole and slot the head.
John
Old 09-28-2015, 10:02 PM   #11
jim1932
jim1932's Avatar
Why deprive them from the same fun we had?
Short URL: http://smu.gs/14g7eDW
jim1932 is offline   Reply With Quote
Old 08-16-2021, 03:14 PM   #12
yooper trooper
That's it!
yooper trooper is offline   Reply With Quote
