Old 11-29-2020, 08:30 PM   #1
DBSHELTON
Default Oil Pump Drive Gear
I am assembling a spare engine and for some reason, I never looked at the oil pump drive gear until I was ready to install it. It is horribly worn! I have never seen one this bad. The gear teeth are almost worn to a point. I have a replacement coming. Is this common? Glad I noticed it while i was rebuilding the oil pump.
DBSHELTON is offline   Reply With Quote
Old 11-29-2020, 10:44 PM   #2
J Franklin
J Franklin's Avatar
Default Re: Oil Pump Drive Gear
Dirty oil makes everything in there wear out.
Old 11-30-2020, 05:53 AM   #3
DBSHELTON
I thought it odd that the gears, bushings, and everything else in the oil pump looked good. Maybe the pump was replaced at some point but not the drive gear. This is an extremely clean engine with virtually no wear on anything else.
Old 11-30-2020, 08:27 AM   #4
deuce5wndw
deuce5wndw's Avatar
How is your cam?
deuce5wndw is offline   Reply With Quote
Old 11-30-2020, 08:33 AM   #5
Jack Shaft
Check your cam plunger spring.
Jack Shaft is offline   Reply With Quote
Old 11-30-2020, 12:14 PM   #6
Jim Brierley
Those gears are available in oversize's, if your cam shows wear this may be needed.
Jim Brierley is offline   Reply With Quote
Old 11-30-2020, 08:34 PM   #7
DBSHELTON
Jim, you just reground my cam a month or 2 ago.
The cam measures 1.556" Should I go with an .004" oversize gear? I already ordered a std gear.
Changed to a new plunger and spring. New aluminum timing gear.
