09-10-2020, 10:53 PM | #21 |
Re: Cleaning an early aluminum intake
Have you seen the finish vapour blasting gives? Looks like brand new!
09-11-2020, 12:14 AM | #22 |
I've gotta say WOW! That came-out pretty damned clean, yet still retains that factory-cast sheen which is destroyed via bead blasting. Bead blasting gets 'em clean, but they never look the same as when NEW! Have you got a brand name of that product? Available at boat supply outlets? DD |
09-11-2020, 01:16 AM | #23 |
With respect, how does anyone know 'exactly' what the factory-cast finish looked like? Not trying to be argumentative, but exactly which of the above pictured finishes exactly matches that of a brand new casting? And how does one verify this?
I still maintain that a vapour blasted surface produces an 'as cast' finish. The problem is maintaining that 'as cast' appearance. Aluminum, by virtue of being that element, soon tarnishes/oxidises just by being in contact with the atmosphere. So, it ends up looking somewhat like the above picture portrays, however, that ain't what it originally looked like! IMHO
Unfortunately, two half wits don't make a whole wit! Last edited by Brian; 09-11-2020 at 01:24 AM. |
09-11-2020, 02:29 AM | #24 | |
The manifold below is a known NOS unit. The surface has an obvious, smooth sheen that can't be duplicated after bead blasting. This manifold below has been bead blasted. It is certainly clean, but the surface is dull with bazillions of little imperfections where the beads have 'moved' or distorted the aluminum finish making it microscopically 'rough' as compared to original. ................. |
09-11-2020, 08:28 AM | #25 |
Soda blasting is another option
Making the simple complicated for over 30 years. |
09-11-2020, 09:09 AM | #26 |
09-11-2020, 06:27 PM | #27 |
The Marine hull cleaners I used were On & Off marine hull cleaners by Marykate ?, and Star Brite marine bottom & hull cleaner. The Star Brite seemed stronger than the On & Off, nut may heave been because it had been on the shelf longer. If anyone is considering this method, clean as much of the oily sludge off the part, and caked grime in corners 1st, do it outside in a well ventilated area, stay upwind, wear gloves & eye protection, and have a fresh water hose handy. You will probably like the results, but not the process. Takes about 2 hours all tol
09-11-2020, 06:39 PM | #28 |
I'm lazy. If they're pretty bad. I bead blast them and find the best looking aluminum paint and paint 'em. I get a lot of positive comments at our local car shows. (I'm glad that you guys don't live up here.)
09-11-2020, 07:15 PM | #29 | |
Never put aluminum in Mureatic acid. It will eat it away. |
09-12-2020, 10:50 AM | #30 |
russcc never use On /Off on aluminum or any other bottom cleaner. It will eat away Aluminum !!!!!!
09-13-2020, 01:28 AM | #31 |
just a thought find someone with an ultrasonic cleaner they work wonders and quick
09-13-2020, 05:45 AM | #32 |
For the pessimist's information the marine hull cleaner didn't touch the Ford Aluminum manifold. Maybe some type of aluminum but not a Ford casting in my experience.
09-13-2020, 11:58 PM | #33 |
A vapour blasted intake would look damn close to that nos one of coop's.
09-14-2020, 09:10 AM | #34 |
You could also blast the parts with glass pearls - this will give it some shine. Or get the parts tumbled, depending on the used stones you could decide what finish you get. Or do as I do and brush the parts after glasspearling - looks very much as just cast.
09-14-2020, 09:32 AM | #35 |
Try mothers mag cleaner an then steelwool sprayed with wd40 works for me
09-14-2020, 12:08 PM | #36 |
I have blasted aluminium and then gone over it with fine wire brush in a drill motor and that gave it a look very sim to that NOS photo above.
Thread Tools | |
Display Modes | |
